X5 Megacycle install HELP! Please.
I learned how in a few nights - was frustrating reading how to do it but it all came clear when I actually got the degree wheel on the engine, made a piston stop and put the dial gauge on the valve retainers to see what was happening.
On paper it will turn your brain to mush, if you haven't done it before. But in practice it is actually a very simple concept and will make sense.
The hardest part is getting an accurate read on the movement of the valves. You need a good solid mount/arm for the gauge and it needs to be parallel to the valve stem to get a proper reading.
I was able to closely confirm the 'cam card' of my Shell #1 grind on a rephased XS650 engine. I was able to confirm 'true TDC' using my piston stop and the degree wheel, and thankfully it was dead-on with the factory marks. But I had to make a new mark on my rotor for the rephased right cylinder.
Honestly the hardest part of degreeing the cam would be pressing the sprocket on and off and getting it into the right spot. Dividing the circumference of your sprocket by 365 and accurately repositioning it 1-2 degrees one way or the other is very very hard to do perfectly, even as mentioned for professionals.
The XS650 cam sprocket is pressed on, not bolted, so adjustments are time consuming. Thankfully my cam measured as being pretty spot-on and I didn't have to make any adjustments. Some performance cams have the sprocket bolted on and are slotted, so you can actually adjust it without removing the cam from the bike at all. The MikesXS XS650 cam is like this but is a piece of Taiwanese cast metal shit.
Yeah the new sprocket that he's sending me is adjustable apparently. It's setting me back $155 so hoping it isn't junk!
I already have a dial indicator and magnetic base so I guess I just need one of those dials and make a "stop".
crazypj said:
Looks like you have one of the heads that needed modifying for stock cam, probably need a lot of cutting to get high lift cam in?
As already mentioned, degreeing cams isn't difficult, just time consuming
You mean the cam housing? Yeah that was A LOT of grinding. Pain in the butt. Got a nifty tool though. A round cone file that goes on my drill. Picked it up at Rona. Works like a hot damn. The best thing since sliced bread though are those green 3M rubber bristle brushes that tear through old gasket material like butter! Goes on the drill as well and doesn't scratch mating surfaces. I tried the gasket remover in a can and it ate my paint. Screw that shit!
