XR200 piston hits crank.
divot02
SRX,CB211
Greetings. I am building an XR200 motor with a powroll stroked crank. I have a 12:1 wiseco piston which hits the crank at BDC. It touches below the wrist pin not the skirt. Does anyone know If I can safely remove enough material to gain clearance. Thanks Greg
So it doesn't touch the skirt? I'm having a really hard time picturing how that would happen...
I don't mean to imply that you're not telling the truth, but rather, would it be possible to get some pics?
Hi Matt. It does hit below the wrist pin. I put a bead of gasket goop on the piston and it contacts the crank where I said. Also I can rock the piston slightly while in contact?
Pictures of the piston should show us pretty well if there is enough meat to be able to skim it off. Any idea how much you would have to remove?
Sent from my DROID RAZR using Tapatalk 4 Beta
If the crank is clearing the skirt, the only place (that I can picture at the moment) that it would be contacting on the piston would be the wrist pin. You can't take any metal from there.
That leaves the crankshaft counterweights, which are not an uncommon place to trim metal anyway. A machinist should be able to help you with that. Balancing and knifing-edging the crank should come in at less than $200.
This isn't a job I'd tackle at home.
Either that or for some reason the con rod is connecting the piston for some reason, but that shouldn't be happening at BDC. Seems like something wonky is going on. Powroll is renowned for good machine work out of the box. What piston do the spec out for their cranks as a recommendation?
well the powroll stroked crank use a shortened rod as well so it is really getting the piston far down at bdc
deciding how much clearance you need and if is safe to remove any at all from the pin boss area is the issue, pics will be needed of the piston
did you have it assembled when you found this out ?
the crank would not need to be turned only remove some material in the correct spot,of course this will change balance rpm's,( a single is not anything like in perfect "balance" only has design "balance" for minimal shaking that is practical at a certain rpm narrow range)it may even be a better spot in the rpm range,that occurs removing the needed metal,may be worse
it may be only a matter of drilling/grinding some material out the opposite side
grinder,drill and scales would be all you need
weigh the assembly,remove needed matrerial on crank under piston at btc
re-weigh crank
remove mo material opposite
its not rocket science,but should be left to somebody with a grip on the entire concept
Pic of piston attached. Thanks for the input.
Do you have any machinist's dye (aka Prussian Blue)?
If you put it on the crank, it will transfer to the piston and we can see where the contact points are.
The motor was together when I discovered the issue. I was checking valve to piston clearance. I have been building motors for 40+ years so I fully understand. I have a stock crank, but would rather use the stroker if possible.
leave the piston a little oily and shoot some paint in that area ,let it dry a bit,will make a good witness mark
the blue is nice to have and use but you may just want to get it done and not go looking fer it
looking close now at that piston it does have some amount of material sticking up right there where it is hitting,right at the oil hole
that is my bet where it hits,anyway
good thing being a forged piston,she has stronger graine strukcher in that area than a cast slug wood
divot02 said:
I wonder how I could find out how much they compress the rod?
the rod is shortened half the increase in stroke of the stroked crankshaft,in other words the SAME amount of measure as the crank pin is moved from center,double-ing this value yeilds the increase in stroke
this away the assembly retains standard piston heght at tdc no need for a spacer at base or longer cam chain etc
I would fit a stock rod to crank and a spacer under cylinder.
I was never impressed with the Powerol stoker kits
That piston looks like it has already had material removed from pin area.
You could remove material from flywheels but that will have a pretty drastic effect on balance
The other thing you could try is contact Wiseco for piston with pin 2~3mm higher
i agree a shorter rod is not usually a a good thing but that is the waythey got along with it..
that piston still has material that can be removed before the cross section there becomes near what it is on the sides a sideways pic would help show that
I'm guessing the raised webs on the piston next to the conrod entry is where it's touching?
I can't see it being a problem milling them down to the same height as where the oil gallies are.
Short of using a longer rod, you probably don't have another option anyway.
The sides will be half the needed thickness or less as they share the stresses.
The main stress on piston is at TDC overlap, if it's going to break that's when it will happen. Forged pistons will stretch a bit before they break, maybe you would hear it hitting the cylinder head?
AS I said, I would replace the rod with stock and fit a cylinder spacer, the only reason not to is for a 'cheater' motor that looks stock
Single cylinder cranks are real easy to take apart and true up, I have no idea how many hundreds of them I've done
It is the pin boss touching flywheels and not skirt either side?
I have machined pistons to 1mm larger than flywheel radius but never into the pin boss
Stock rod ? May run into cam chain length issues . It wouldn't be the first time I've had to take a bit off the crank wheels opposite the crank pin on a Powroll stroker . Balance ? really ? it's a fsckn single . Just take off the amount you need to .
however ...
If you can get the cam chain up and over the cam sprocket there is nothing wrong with a spacer other than the upper motor mount . If the cam chain won't make it you end up adding length to the chain and it ends up at the end of the tensioner travel .
Just wondering what Powroll has to say .
~kop
