Xs 250 Carby tuning sad sad times
Josh Fountain
Hey guys I've got an xs 250 that I've been trying to fix up, it's making me very sad as its a piece of sh*t. It never used to idle and ran on 1 cylinder, I pulled it apart, new needle and seat and cleaned the jets out, cleaned everything out in the Carby, put it back together and now when you start it, it revs off the clock on both cylinders, but when you run it on 1 cylinder - LH cylinder idles perfect, RH cylinder hovers a little bit but still a decent idle, but when both plugs are in it revs right out,
I have no idea, giving me a headache, has anyone experienced this issue before?
The main jet is #117.5
Pilot is #20
Has straight thru exhaust,
Pod filters, when testing it has standard air filters
If anyone knows what might be causing this it would save me so much trouble
Cheers!
