XS 400 LED conversion
gmkieran
I'm in year 2 of converting my XS400 Frankenstein ('79-'81 pieces throughout) to a cafe-style ride. This year is seat and electrical. It's coming along well, but the LED turn signals I'm trying to install aren't co-operating. The wiring harness is part of the '81 era bike, so I've already done things like remove the dash indicator (because the LEDs light up all four at once with it installed) and replaced the stock relay with an electronic unit. I know that the new flasher works, because I tested it with the incandescent lamps. I know that the LEDs work, because I can get both sides to light up when I hit the switch. I've also determined that the auto-cancel relay interferes with the LEDs and is unnecessary (in terms of the circuit), so I've removed that from the equation. I do have a 4 volt drop-off between the battery and the signals (1 volt gets lost in the headlamp - can't do anything about that), but I haven't been able to track down where it's all going.
Has anyone done this conversion? What did you end up having to do to get it to work?
Thanks and Cheers!
Grafton
well if it helps at all i too tried doing an led conversion on my 79xs400 and ended up dropping it and only having LED's in the back. the relay i used was specific to the signals in the front and all i would get is whatever side i turned on it wouldn't blink. only a solid light. my advice to you would be to just go to your auto parts store and just try out every 3 prong relay (if its the same as mine) until you find something that works. if it doesn't just bring it back. to this day i still have no idea why i couldn't get them working. worst scenario you go a different route. good luck
Welcome to the fold, Grafton!
My theory of the day is still the harness ground for the flasher relay, but I reserve the right to change my theory as new information flows.
Also, do you have the pinout diagram for the flasher unit?
-W
I had this same problem with my CB360T. I removed the turn signal indicator light and now they work fine.
I did it on my wife's XS360, which is full LED except for the headlamp. I ended up using an electronic flasher, but probably not like what you got. This one was not load dependent, so flashes at a constant rate regardless of what is hooked to it. It is actually a three wire hook up, as the flasher has its own ground--ie power in, flash out, and ground. pretty simple, and your flashers are always constant. I got it at CarQuest, but it is Grote flasher.
Here are the numbers. Not sure which is CarQuest and which is Grote, but you can try either at any auto parts store
Grote (I think): 01-4489-12
CQ (I also think): 44891
Thanks for the thoughts, all! xsquad3, you may have had the same problem I found - a severe voltage drop into the handlebar switch. With the old-style flasher it wouldn't matter, because those are amperage based, but the electronic flashers require at least 11 volts coming through to work. I'm replacing the lead from the switch to the harness to see if I can get the voltage back where it should be.
Bozz, I'll keep the theory in mind - if replacing the lead doesn't fix it, I'll check that next. I worked out the pinout diagram the hard way, because the configuration was different from my original and I had to re-arrange the plug wiring to make it work, but I do have it, now.
Skatetheame, glad to hear it worked for you! Taking the indicator lamp out did get me to the point of not having all four corners come on when I hit either side, but still no love on the flashing.
T71Ford - that's what I'm going for. I've got a supposedly load-independent electronic flasher unit but that does no good if it's not getting the voltage from the switch.
Wish me luck!
Final resolution to this, if anyone is interested: 1) buy the correct flasher unit - I ended up with a Tridon EP34, which is LED friendly and has the same pin config as the OEM flasher for the XS400. 2) track down the faulty ground wire from the harness to the flasher and replace it with a known-good-ground. Back on the road! :D
If you have 12 volt . . .
http://www.truck-lite.com/webapp/wcs/stores/servlet/GenericView?pageName=/new/PressReleases_en_US/12vLEDHeadlamp.html&storeId=10001&langId=-1
I'm trying to understand your problem. I think you've already been given the answer you asked for, but either you didn't recognize it or I don't actually understand the question.
Flashers work because of resistance. Some of that resistance comes from the wires and switching (that's all the indicator switch does is route a pulsing signal to one or another set of lights) but most of it comes from the bulbs themselves. If there is not enough resistance in the line most flashers won't work.
Why "most"? There are two different types of flashers. With one type there are two wires, one takes power in and the other sends a pulsed power out. There must be sufficient resistance on the line out for the system to pulse. LEDs offer very little resistance compared to the incandescent bulbs these flashers were designed to be used with. The second type of flasher will work independent of resistance on their output line. That is because they have a third line which is grounded, or they have a case that has to be grounded, but in either case the resistance that is required to make it flash is provided by the grounding of the unit.
So, if you've got the first type of flasher, a 2-wire unit, and you put LEDs everywhere in the system there won't be enough resistance at the flasher to make it work. The solution is to get one of the other kind (3-wire or case-ground) flashers that will work with the system. An alternative is to put resistors in the circuit but its not really the best way to proceed. If you put in resistors it will cost you as much or more than just buying a grounded flasher and at the same time it will require you to splice yet another part into your electrical system and complicate it even more. A new flasher is a less expensive and simpler (what we like to call more eloquent) solution.
To simplify and sum up how it works: Once there is a pulsing on-off signal coming out of the flasher it just goes to the control switch where it is routed to the appropriate set of lights (left or right side). One way to think about it is like this. The flasher system is just like every other circuit in that it begins somewhere and ends somewhere. Power into the Flasher is the beginning of this circuit and it terminates at the grounding of the bulbs. So, the battery provides the voltage and amperage necessary to make the bulbs emit light and the bulbs create most of the resistance needed to operate the flasher, the switch just directs the signal to the appropriate bulbs. That's how it works in older systems. Newer systems differ only in that the flasher is somehow grounded so its operation is not dependent on the bulbs.
i read this the other day and have been working on getting some turn signals working on my bike. after lots of electrical wire repair i hooked up my front and rear led turn signals, went to the local autoparts store and bought a Tridon EP34 3 prong flasher. plugged it in provided a ground wire and i have 4 LED flashers that flash. i thnk the flasher cost me $10 and it took me about 3 min to make a ground lead for it. im so happy now
