XS250 CDI compatibility
rickee
Does anyone know if an XS250 can run with the CDI from the XS400? Just bought an XS250 for a song but found that replacing the missing CDI is going to be a challenge as they are rarer than Hen's molars and less easily found than rocking horse manure.
Thanks!
Richard
My manual says the only difference between the 250 and 400 is engine parts relating to the larger capacity. That may include the Cdi. You need to check the part numbers on both models.
I know that's not particularly helpful. If you can source the complete 400 engine, they are a considerablepower upgrade
Thats cool, I'm picking the bike up on Tuesday. The guy I've bought it off had it as a spares bike for another 250 so I can check the part number off've his for that. Does anyone have the part number handy for the equivalent 400 part?
Can't do the upgrade to 400 power for a while as the bike is for my wife who is a learner. The learner Laws in Australia lets her ride up to 250cc (if accompanied by an experienced rider) but no more until she passes her test.
Thanks!
Richard
What part of Australia are the laws like that? Not in vic where I am. Anyway, I checked up again and depending on the model year, it will probably have points. I'm not sure any xs250's came with a Cdi. My manual lists the ignition timing dwell angle etc as the same for both 250 and 400. from that I assume the points are the same across the different models. http://www.cmsnl.com/ has the parts diagrams of the xs400, there are a couple of different engines, and the year/models are not the same as the Australian models, but one of them is the one which is cross compatible. The physical parts won't have numbers on them that will be useful in identifying them, so take a camera when you pick the bike up, and get some shots of all the guts of the ignition you need to find
I'm in WA. Moved back from the UK after 20 years away. Driving standards and training are pretty lax here compared to other states.
The 250 is an 83/84 special. The one with the monoshock and definitely CDI. This one (http://www.gumtree.com.au/s-ad/birkdale/parts/xs-yamaha-250/1006061134) has the same frame and you can see the CDI behind the reg/rec. The one I've just bought has the two plug connectors but no black box :(
if the timing and dwell are the same then the only thing that might be different is the rev limit, I'd have assumed the 400 is 500rpm or so less on the redline? Might work.
Oh hang on, is that box TCI and not CDI? I found a Japanese shop online that shows pictures of a matching box with the part number T1D12-10.
Ok, disregard my info about ignitions being the same then, I'm going off the manual for twin shock models, which have a different engine. Have a look at the diagrams on csmnl, and then search Ebay with the part number, often the Ebay Sellers don't list all the models. Also there is a part finding Australian based http://www.findapart.com.au/ , which bulk emails motorcycle wreckers in Australia and new Zealand,which have had success in using in the past.
