Xs400 electrical power output
MILLENNIUM FALCON
Over 1,000 Posts
DTT BOTM WINNER
Does anyone know what the safe maximum draw an 82 xs400 can Handle. I would like to put a light on my sidecar but I don't want to overtax the charging system. I am currently running a 35w headlight with LED stop/tail/turns. Any info would be great. I have searched and looked in my shop manual and it doesn't give a straight answer.
I still dont know much......I am running led driving lights on the side car in addition to the bikes lights with no problems.
Wow that's a lot more than the old SL350! Might have to look into doing something different with the headlight, Im running an LED tail light and im going to be adding another tail light because you can never have enough light on these little bikes.
Does anyone know how much the coils use as far as watts? Iv got a led tail light and all other lights are now leds so Iv saved a little power on that. But I want to know if the bike can handle a 50w headlight or if I should stick with a 30w,
Im installing a new bucket and it came with an old 6v bulb this is what im looking to replace it with
30w
http://www.bulbs.com/espec.aspx?ID=10725&RefId=26
50w
http://www.bulbs.com/espec.aspx?ID=10745&RefId=26
From what iv read online its 3.9-4 ohms. There are still stock coils and the bike has points.
Also I use the electric start a lot but the headlight is in on a switch since its a pre 1978 model so I cut the headlight off when starting to save some power.
So the amount of power the coils use is going to be dependent upon the dwell, but let's assume the points are closed 75% of the time.
The power used by a single 4 ohm coil at 14V would be 2.63 amps (14V / 4Ω * .75 = 2.625A). 14V * 2.63A = 36.75W. If you're running two coils then it's 73.5W.
But if dwell is reduced to 60% of the time and you're using a 5 ohm coil, the numbers change. Total Wattage for two coils comes in at 47W.
Lower wattage often (but not always) means a weaker spark (especially as RPMs climb), so it's all a trade off.
Ya I knew the old coils wouldn't through out much spark and plan on going with something stronger at a later date just to jet 1-2 HP that might be hiding.
I looked to see how many watts the led tail light would pull but cant find it anywhere.. Im assuming 10w max.
So im looking at 73.5w coils+ 10w tail light+ 5w spedo light and dashboard lights=88.5w used when headlight is off. So that gives me 91.5w for the headlight and any other systems I want to install!?
Sounds like a little to much left over power but that's just me. well now thinking about it it makes sence that I will need some power left over to charge the battery.
Im not shore I under stand what dwell is?
And thanks for the help im just starting to learn about ohms and some of the more in depth parts the DC
Dwell is the period of time that the points spend in the closed position. The longer the period, the more wattage you're using. Go too short and the spark strength suffers.
I got ya so it would be something that could be changed with tuning the points. Also from the way I see the coils they are like a big capacitor. They build up charge then when the point closes the charge it dropped into the spark plug. which is why the spark does not keep sparking when you cut off the motor with the points gap closed.
Is that a good idea of how they work?
Sort of.
First up, you can't usually adjust the dwell. It's set by the manufacturer. You can regrind the cam if it's something you want to play with, but I don't recommend it.
Coils work a bit differently than a capacitor. They don't really store a charge. There are two windings of wire in a coil; the primary and the secondary. The primary winding is connected on one side to your bike's power supply. On the other side, it's connected to the points. The secondary coil has one end connected to ground and the other end connected to the spark plug. With the points closed, power flows through the primary coil and creates a magnetic field. When the points open, that field collapses and induces voltage on the secondary coil. Electricity likes to flow in a circuit, so the two ends of the secondary coil will attempt to transfer electricity between one another and since one end of the secondary coil is grounded, the high voltage will jump the gap in the spark plug to meet up at ground.
The primary coil may be wound 10 times around the core of the coil, where the secondary coil might be wrapped 1000 times. It's this different in the number of windings that generates the high voltage you see on the secondary coil. So a coil probably has more in common with a transformer than with a capacitor.
Ok that makes more sense. I under stand how winding of transformers can step the voltage up like they do in a welder or a microwave. I really need a good multi meter so I can read ohms to test parts...
So saying I have 91.5w left in the system. So how much power do you think I will need left in the system to charge the battery? I will be changing the battery soon but I will be using somewhere between a 8-12ah battery (it will depend on how small of a led acid I can find) I want to have enough power to still have some left under max load(high beam on running down the high way) this will be for future moods)
Iv tried to see how many watts the battery needs to recharge while running but I haven't seemed to stumble upon any info on the topic on google (more than likely using the wrong key words to search)
So im guessing the battery needs 2-6amps Witch would mean 28-84w, I don't think I will need 6amps to charge the battery while running I believe that 2 amps will be enough to keep the battery topped off.
Witch 91.5w - 28w = 63.5w that I could use for a headlight.
28W is a healthy number. The battery's wattage consumption will largely depend on it's current charge. As a battery becomes more charged, it's internal resistance rises so that the battery will use less and less power as it nears full capacity. On the flip side, if your battery's charge is very low, it will have low resistance and will pull much more power out of the charging system. With a dead enough battery, it may pull more than your charging system is capable of putting out, leading to dimmed lights and such.
Ya iv had the dimmed light effect.. The battery iv got now is 3 years old and has been drained to nothing a few times and sat long amount of times with no charging. So it was at the end of its life and Iv had to limp it home a few times. I tried a trick that seemed to work for a little over Christmas to get a few more rides out of the dead battery. I made a mix of epsin salt and hot water and filled the cells that were low. Then shook the crap out of it!! This was to get the build up off the plates so it would hold a charge. And it worked for the 3-4, 20-50mil rides I did. But it was still week on start ups but once it was going it ran grate! Wont be a end all fix to old battery but could get you out of a tight jam or get you a few more rides out of the old one!
Im going to be finishing up college this spring and plan on doing a bike trip for a week! So im looking at charging cameras and my phone from the bike while ridding so im trying to get the charging system right. Something else im looking at is getting a little 10w led light that will put out around 900 luminous and install it on the bike for the trip. I would get a flood light so people could see me from any side in front of me but not be blinded with only 900lum. Then that would mean I could turn the headlight off and just run with the led headlight and led tail light leaving power to charge phone and cameras. Then at night run the led with the headlight for even more light!! (sry im obsessed with having bright lights! Iv had a few jeeps that would blind anyone in my way and a WRX with rally lights just so I could see that much better!)
