XS400 Project
man... that is one hell of a shop you have there! love how the trees match the frame! hell i may even pull mine apart to do the same! that really looks good man! i showed this color and the blue to a few buddies this weekend...everyone is really feeling it!
You have no idea how sweet of a shop it is. My dad is one of the top Porsche 356 restorers so at any given time there is around 8 of them there along with a variety of other nice cars. He has a hoist, a ultrasonic parts cleaner, sand blaster and his business is wholesale automotive tool distributing so the rest of the building has every tool you could ever need. Hopefully I'll buy paint next week and get the tank and the seat done so i can really see how the colors will work.
just awesome! i had a 944 turbo for a bit in college... i beat the car to death and then sold it for over a grand what i paid for it... great ride... i am a HUGE porsche fan! you have a good spot there! where you located?
Detroit suburbs. 944 are cool my dream car is a 914-6 but i love driving the 356's there not all that fast but there still a lot of fun i've gotten to go on a few rallies in them and its so much fun. I couldn't afford to rebuild a 914 so i got a bike. As much as i love bikes now i hope to one day get a 914.
Got a bit done today. Decided to try and tackle the wiring harness. Wrapped the whole thing in a fresh coat of tape and got a bunch of it done it looks pretty messy but space is very limited. I'm hoping to clean it up a bit and get more hooked up in a few days.
What kind of battery is that, and what are the dimensions of it? I need something that'll tuck under my seat cowl...
Dude I'm loving this build! I can't wait to see the final product. How's the wiring harness coming? It looks a bit intimidating. I just got the wiring to work on my bike.
Thanks. The wiring is a bit of a pain I'm using the original harness and since i moved a bunch of electronics the wires are all too long and there is a lot less space. So if i want to keep it looking clean so I'm going to have to really stuff it all under the seat or shorten a lot of the wires. I can see why if you know even a bit about wiring it would be a lot simpler to just redo the whole thing but its not in the budget there are too many other things i need and too little money.
Got a bit done today greased the swing arm, put on the gauges and ignition, then hooked up just about everything to try and test the wiring harness and not much success. There is power the oil light and neutral light come on and after hooking up the clutch lever and pulling it in the horn worked. I'm not sure what to think about that besides i need to get everything hooked up and then I'll be able to try and figure it out. Made a license plate bracket but i still need to figure out some kind of light for it. I'm going to order a headlight, petcock and adapter plate, fork seals, oil filter and headlight brackets today i think so once i have the headlight i should be able to get the front signals mounted and have a headlight that's working and figure out the rest of the wiring and be able to get the front end together and get it rolling.
can you take a close up pic of how you did hook up the clutch, i want to make sure i hooked up mine right... my old azz manual sucks!
all i hooked up for the clutch was the wiring for the switch in the lever are you wondering about the cable to the clutch here is a photo of it after i took that side cover off during the tear down. Hope it helps.
Lite 'n Boltz are great to light up the license plate. I have them on a couple of my other bikes. Cheap, but light things up pretty well.
That is exactly what I've been thinking about using. They seem to be the best bet since I'm going to make a second bracket to mount the plate horizontal for when i take my road test and if i get a fix it ticket. Plus i don't need to make another bracket for a light.
JRK5892 said:
i was hoping that ours would be closer to the same... i just hope i do not have to pull it all apart
Sorry i couldn't help. You might want to try one of the parts web sites with all the diagrams. I like http://www.stadiumyamaha.com/ there site is the simplest I've found to look up diagrams.
Quick update ordered the headlight, headlight brackets, petcock and adapter plate, fork seals, and oil filter from Z1 hopefully I'll get them all by Monday and things should really start to pick up pace.
Yeah, I use them on an undertail mounted license plate and a swingarm mounted one. The only issue I have ever had is when I want/need to remove the plate I have to disconnect the wiring.
Got a few things done today. Tossed the fork tubes and springs in the ultrasonic cleaner to make sure i got all the old oil and any debris out. While that was washing i hooked up my front turn signals to test the harness and flasher. Then i had a ah ha moment when i realized the reason i was having issues with controls was they were not grounded and were just hanging there so i pushed the edge of them on the engine and everything worked and it solved the odd problem of the horn only working with the clutch pulled in. On the down side if clipons end up in the budget like I'm really hoping for it wont work to paint them blue like the tank and seat like i was hoping. Although i could solder a wire to the inside of the handlebar controls and run it to a ground cable somewhere in the harness. Anyways if all goes as planned Monday should be a big day I'm planning on having the front end in and the bike rolling as long as my parts come. I'm getting pretty excited for this to be done i even spent some time watching tv with my helmet on the other day. Hopefully the automotive industry picks up and i can get a few good 60 or 70 hour weeks in at work and finish this thing off.
Went back to work this week so i haven't had time to work on the bike till tonight. Got my parts in on Monday and after a lot of messing around got the headlight together. Tonight i got the fork seals in and the forks back together. I just need to pick up some fork oil on Saturday and should be able to have it on its wheels. I put the forks on to see how it looked. Also changed the oil filter.
