I'm wiring up by XS650 brat right now using a simplifed wiring diagram. I've found a couple of sources of knowledge out there, however they seem to contradict each other on the subject of the reddish brown wire coming from the Alternator loom as below (the one from the brush assembly I assume)
Basically, can anyone confirm that they ground this wire out and nothing bad happened? I have seen that some people hook it up to the ignition line to send power to the brushes when the ignition is on, and I see this diagram that just grounds it out...
I'm confused!
I'm confused!
