xs650 cafe
Lets make sure you're using my last diagram :)
So I have been taking stuff off and cleaning some, but mostly studying the wiring. I have been having some trouble identifying some electrical components, mostly due to some colors not matching what the diagram says they should be. Maybe someone here can help
This is under the tank on the left side of the bike, six wires,
This I believe is my rectifier
This is under the tank on the right side, 3 wires, maybe flasher relay
This was attached to the battery box I believe (not under there is a black box that I believe is my ignitor box under the battery box)
This might be the safety relay, but not sure
Just a sample at the grime that has collected on this bike over the years.
Any help would be appreciated.
A little update.
I have been slowly tinkering with the bike for a while, no money, I do what I can. I have been messing around with the wiring and bought a new sealed lead acid battery. I found a couple bad connections and fuses and now have power to my lights and horn, but am not getting any spark. next up is to figure out why not.
On a side note, I have been talking to a buddy who has a lot of equipment (ie. metal working mill, tube bender, and A LOT of knowledge). As soon as I can get my bike to him he is going to make me my custom exhaust, maybe some rearsets and hook me up with a bundle of electrical equipment, enough to rewire the whole bike. My only hold up is I just moved 4 hours away and don't have a job yet so my wife is not very happy with me wanting to spend the money on gas to drive up there and back, so it will have to wait until I have a better excuse.
I will try to post some pics, and try to get more done.
So during my tinkering on the bike I found something that kind of has me worried. I am new to bikes but it just looks weird. The front tire does not look straight with the handle bars straight. here are some pics..
With the tire straight
I can't find anything that looks bent. The only signs that something might have happened are the headlight connectors (see pic) and the headlight where it connects to the connector via the blinkers (as I write this I am reminded that the bike only came with 3 blinkers, 2 in the back and 1 in the front, maybe it got laid down or hit by something).
The angles are different on the two sides, the weird part is I can not find any signs of damage, it looks like two different ones are on there.
Any help from you moto gurus out there is very appreciated.
I have a yamaha xs400 and the headlight ears look exactly like yours, so that is not a problem. I am not sure if on the xs specials if the headlight was supposed to be off center or what. I ended up replacing these ears as I could never get it too look right and the mounting rubber dampers had all dried up and cracked.
As far as the front tire not being straight, perhaps it is that the forks were off center before everything was torqued up. Try loosening the upper and lower fork bolts along wit the front axle. THen try putting the front fender back on, it has a support that should be used and tightened first as it will help line up the fork tubes. Then tighten everything up.
where are you located?
i've got just the brace piece from the front fender if you want to run without a fender.
you can have it.
"Straight" solution: the 'old school' bikes have some relatively skinny forks and clamps. Loosen the triple-clamp bolts that hold the forks and make sure the steering stem bolt isn't over tightened; then grab your handle bars and smack your wheel against something solid like a tree or a wall (being cautious to 'smack' the rubber part of the tire and not anything painted like a fender) and re-check the alignment. You can "string" it if you want to make sure it's perfect.
No big deal.
-KR
Thanks for the responses. I will check the fork bolts and triple tree bolts to ensure everything is straight. I will probably figure out my ignition problem first so I can see it run for myself before I start too much.
mrkill- I am in oregon. I have my fender and planned on cutting it down but it is in perfect condition and almost hate to cut it up. Maybe I could fab up a small fender to put on your brace, I have to have a fender by law. I will PM you.
Good to see another xs650 at the Ton. I got mine eariler this year and did a budget build ($1000 total) and got her running and on the road. I will probably do other mods this winter but wanted it rideable for the summer. I would be interested in your seat pan if you are not going to use it. Keep the posts coming...
Cretin- I am not sure if I will keep the seat pan. I am going to fiberglass up a single seat, but I also want a two up, I am thinking I might fiberglass up a two up seat but who knows, all that will happen this winter hopefully. I will definately keep the seat pan until then though. I will let you know
So I got some work done on the bike this weekend. I took out a bunch of electrical components that were unnecessary and everything works the way it did before. I still do not have spark but I kinda gave up tracking the issue down due to the fact that I am going to replace the ignition with a Pamco high output system. I know it ran before so I am just going off of that.
I also started tearing it down.
I need to buy a special tool to get the tripple trees off because of the nut holding them on (unless someone knows a trick for that as well) I will be continuing to tear it down for some minor frame mods and paint later on. Also I will need to do some grinding to get the kickstand off, they welded the nut on.
it will be slow but I will make some more progress and do as much as I can with no money to prepare for when I can buy some much needed parts.
Those nuts (should be two - they act together to lock in place) can be removed with a rear-shock pre-load adjuster tool.
Or you can just use a blade screwdriver and a hammer to tap the top one loose. The lower one should then just spin off, as it should not be tightened down hard (if it was the steering head bearings would be locked tight and it wouldn't turn freely).
So I did get the nuts off the triple tree stem, and a few other things, it is literally the frame, engine and swingarm. I am looking at the swingarm and it does not want to budge. I thought a little persuasion with a hammer and a block of wood might do the trick but it didn't.
any tips?
Once I get it off I will tip it over and remove the engine, then work on removing the stand and prettying up the frame from all the extras that have come off. Later on I will weld a tray on for the electrics.
I know this is a slow build but it will come out alright in the end (whenever that is).
Hey dude, with your swing arm pivot bolt, lay whats left of your girl on her side and spray some wd40 with a nozzle extender into the gap around the thread end and leave it for a time, then get your socket onto the headed end and try to get it turning, (add more wd40 if required) then once its turning give it block and hammer treatment, good luck cheers Andycafe
any tips?
6 hours with a drill worked for me. The swing arm bolt was rusted to the bearings and it was a lot work to get them out. I basically drilled the bolt on both sides till I could slide the swing arm out then with a 5lb hammer popped the bolt out. It sucked. Good luck with that
Jay
Ditto on it sucking. I had to cut either side of the pivot bolt with a small hacksaw to get my swingarm off. The sleeve becomes one with the bolt over years of neglect. No amount of PB Blaster, heat, or sledge hammer is going to break it loose LOL
Thanks for the inspiration :-[!!!
I will see what I can do, the nut came off fine, it is just the bolt doesn't want to come out. I will try to add some pictures, it might not help but I will do it anyway.
Thanks for the tips
