xs650 cafe
The nut on mine came off fine too. The pivot bolt rides inside of a bushing/sleeve which rides inside of the swingarm bushings. The sleeve and bolt rust together and become one over time making it impossible to drive the bolt out.
Exactly the same scenario for me. Don't mean to rain on your parade but set yourself some time and buy the best drill bit you can for hardened steel that will help a lot. Lets just say my poor dad's ears were turning blue with my words coming out of my mouth.
If you drill out the bolt, lay the bike on its sides so that you can get more pressure on it.
Jay
I cut between the swing arm and frame using a small hacksaw like this and about 25 blades LOL. Only took an hour. That was after trying to get my sawzall in there with no luck.
Any thoughts on Part #28-1011? it is the Swing arm Needle Bearing Conversion Kit. How does it improve the bike? is it worth it?
I do not know anything about the needle bearing kit. Seems to me I ended up putting new bearings in the swing arm of my KX125 any time I pulled the pivot bolt out though...and it had needle bearings in the swingarm
Tim said:
Lets make sure you're using my last diagram :)
Hey Tim,
I am curious as to why you chose to use just one fuse at the battery and none anywhere else? I am in the process of redoing my wiring and would like to do it just one more time and then never again! LOL
Thanks Dave
Unless you intend to race or keep the bike for a very long time - just go with the bronze bushings. You'll get plenty of service life out of them as long as you keep them properly lubricated.
As to the issue of stuck bolts, rusted fasteners, etc. There is ONE product that really and truly works. It ain't cheap but you'll be amazed at how well it frees up hopelessly rusted stuff. Kanolabs makes AeroKroil. At $11 per 10oz aerosol can or $16 for $16.5 oz "Industrial Size" aerosol can it is two to three times the cost of other products (PB Blaster, etc.). BUT - it is worth every penny.
You can order direct from Kanolabs on their website: http://www.kanolabs.com/ or from Eastwood (home away from home for many auto/aircraft and motorcycle restorers) at http://www.eastwood.com/catalogsearch/result/?q=KROIL but beware their silly mark-ups.
Have fun!
isleman - So I am building a race inspired bike, and am very much into performance over looks, although looks are important. I doubt I will ever really race it but I am looking for as much performance as I can get (within reason and time). I do want to max out my handling on the curvy roads here. Is it worth my time to upgrade to the needle bearing kit for my swingarm?
I guess what I really want to know is what kind of performance am I going to see from the upgrade?
Such a slight improvement that not even your highly calibrated buttometer will be able to detect it. Hell, I'd bet that from one lap to the next, not even the highest level flat track racers would be able to tell if they didn't know up front.
If it inspires you - do it, if you're on a budget - not so much. The point being that needle bearings in the swing-arm are completely invisible once the swinger is installed. You would know they're there - nobody else would have even the slightest inkling.
Race inspired is good. Doing stuff that makes a genuine difference is good. The difference between needle bearings vs. bronze bushings in the swing arm - eh. Not such a big deal. Tapered roller bearings in the stem...now THOSE are mucho lucious goodness. Creamy good even.
So, It's been a while!!!
I was busy with other responsibilities and out of town for a while and let's face it, a little bit unmotivated by the lack of money to buy any parts, so I didn't do much for a while. I did remove the engine, not yet the swing arm, but that is in the works. I have been spending my time cleaning the almost 30 yrs worth of crap on the engine and grinding away some useless stuff on the frame. Any tips for cleaning in between the fins? A rag, engine degreaser and a flat head screwdriver has been my weapons of choice so far.
I have been making progress on that stuff since it doesn't cost anything. I also have some stuff ready to take to my buddies shop to get done, Drill the rotors, make some rearsets, and some other randoms, could do the exhaust but am not putting the engine back in for a while. I could add pics but it wouldn't show anything remarkable.
Cretin- If you still want the seat PM me and we can make arrangements, I already cut off the original mounting tabs to make my fiberglass seat a little slimmer.
