XS650 Pamco help, please...
VonYinzer
Over 10,000 Posts
76 XS650. Pamco ignition. PMA kit. PWK carbs from MikesXS. Solid clutch pushrod upgrade.
So, rewired the entire bike. Nice and tidy. Added the go juice, and kicked her over. Nothing. Cleaned the dirty plugs, adjusted the Pamco (blind... more about that is a bit) and she fired up on first kick. Idled for half a second and shot to redline. Shut it down. Adjusted again. Same result. Eventually, when fully retarded the bike would start, and sputter... Than die. No throttle response at all.
Tinkered for a couple hours and cannot get the bastard to idle.
So... Checked for air leaks (very half assed, as I have no access to most of my tools) and cant seem to find anything. Idle screws all the way in drops the RPM a hair. But nowhere near what it should be.
So... Thoughts? I ran out of daylight (working in my brother in laws yard, only enough room in the garage to wedge the bike in for storage) and patience. Will get back at it (pending the possible rain) tomorrow.
Also, if anyone out there has a Pamco XS650 instruction book they could scan and EMail me that would be much appreciated.
Thanks in advance. This fancy pant electronic ignition is all new fangled to me. Newest bike Ive ever had was a 75 RD200. Hahaha...
Know it sounds simple but is there a kink in carb cable ? Dont sound like a igniton problem sounds more in the carb area maybe?
Nope. Slides are where they should be and the cable is free. Thats one thing I made sure of from the get go. Thanks though man. Its always the simple stuff like that that ends up screwing ya.
It's not likely the Pamco. The mechanical advance is working correctly I presume? Even that wouldn't cause the engine to race like that.
Did you take the head / cam off? No chance the cam is a tooth off?
As you know the only difference between the Pamco and a points ignition is no mechanical points - just a magnet and a sensor. The rest is the same. You're running 5K ohm plug caps and/or 'R' type plugs?
I have the same set up on my 650, pamco and pwks (pukes) when I cold start on the chokes, the bike takes off like a feckin rocket... 4.5k - 5k idle. I end up with one side choked and one not until it will run with no choke. Are your air barbs blocked off. Sounds like it's getting extra air to go with the fuel the chokes are dumping in.... My carbs are set with the factory main jet and one size under idle / air... With the screws 2.5 turns out... Hope this helps... Set my pamco up initially per his website and then set it up with a timing light once it was running...
Mechanical advance seems just fine. Head, cam chain are untouched (unless the PO is lying... wouldnt be the ifrst time).
NGK 5k ohm caps from MikesXS with their dual outlet coil and NGK plugs. Cant remember the exact plug details, as the bikes across town at my brother in laws.
I know all of this seems silly. Just driving me nuts. Its probobly something stupid as usual, but before I start going all out I just want to hear what yinz think.
My time and resources are pretty limited until we get my brother and sister in laws house renovated so I just need to be sure of every move before I make it. Working in the dirt driveway is a big enough pain in the ass. Haha.
Thanks guys.
Thanks a ton. I had both carbs choked. Wouldnt start otherwise. The air barbs are plugged, yes.
The only other things to check on the ignition are really that it's firing on the correct cylinder, and make sure the ATU is free and working properly. If you removed the ATU make sure that all the pins are in place behind the unit.
Have to say though, it does sound like it's more likely a carb type issue though.
You might want to check into info on XS650.com if you haven't already. Those guys know way too much about the 650's.
Von, the installation instructions for the Pamco are on Pete's site: http://www.yamahaxs650.com/ also you can fire him off an email at help@yamahaxs650.com
Thanks Herr. Havent been able to spend any time on the computer so I didnt have a chance to look for that online yet. Definitly saved me some time. Im sure its probobly an air/fuel issue. Just want to make sure I cover my bases. Thanks again everyone.
Does yours have the Vacuum petcocks? I had a similar issue with those on an XS650 I had. I replaced them with the non vacuum ones from MikesXS and everything was fine. Before it would only run on the "Prime" position until it fouled out. And by run I mean run erratically.
If you can't find an air leak, I would double check the advance mechanism. If the springs and clips came from mikesxs then the springs are probably too weak. A lot of people complain about their springs. You could try taping around the weights so they don't open and see if it stops racing up the rpm's. Or, if you have OEM springs, try putting them back in. If you find the springs are weak, you can cut the end off and bend one loop up to hook it. Do one at a time and if it still advances too quick, do the other. Then check that you are getting full advance at 3500 rpm's. If not, slightly stretch the springs one at a time until the timing is right.
Rad, thanks man!
