xs650 starter hole size
Juggernaut
I'm wondering if anyone with a 650 can measure their xs650 starter hole to see if I can use it on my xs750. I found a block off on mike's xs but I hear he doesn't like answering questions about cross referencing parts for other bikes.
I have a spare engine I can take a measurement from. The starter is still on there though so the number may be slightly rough. Will that work for you? I hate to sound lazy, but everyone is still sleeping when I get home, so I dont want to bang around in the garage taking it off.
That's not problem at all. My bike is still in a 1000 pieces. Don't make too big of an effort like taking things apart unless your going to. Thanks.
Just measured a starter motor case seal.
Outside diameter is about 46mm, the 'hole' is about 36mm
If the outside of seal is 46mm and the hole is 46mm it should fit perfect.
Does block off plug from Mikes fit into hole in seal or do you have to remove seal and fit plug into crankcase hole?
Starter Block-Off Kit - Kit is used to block off starter motor hole when starter
is removed and bike is to be started with kick starter only. Fits: 1972-84 650's
I don't see a seal in the kit. Hmmmm. What do you think? I assume there is a seal on there b/c a metal to metal contact would not seal completely. I should just risk it to find out.
