XS650 steering head bearings
Terry
you know how one small job turns into somthing totally unexpected? That's happened to me and my XS2. A simple head light ears and wiring cleanup has exploded into a steering head bearing job. So, Anyone got any helpful hints? Such as: 1. How do you get the old races out?, 2. What type of grease do you use on the bearings?, 3. I've been told that getting the new races in is easier if you put them in the freezer for a half hour or so to contract the metal, then a little grease on the neck of the frame, then tap them in with a block of wood and a Big F****ing Hammer. Anyone tried this method? Will it work? The XS races are recessed into the neck, so will a piece of PVC or a socket work to tap them home to the correct depth? this is the first time I've done this job, so I'm trying to get it straight in my head before I start. Thanks for the help.
Terry
J'ville, Fl.
