When you roll out of the throttle, the motor is still working hard and creates significant vacuum in the intake, so it could be something on that side. Or it could be that when the throttle is shut, there's less mixture to burn and less pressure on the top of the piston, so the rod stretches slightly.
If you stick it in gear with the front wheel against say a wall, and start to let the clutch out - carefully, does the noise get worse? If so, it's a big end with too much play in it.
If it's only there when you shut off, then it may be piston slap. That 80 psi reading is a good indication that something is seriously wrong and that the motor should come out to be fixed.
