xb33bsa said:oh and lots of bikes you can do a clutch without even an oil drain,by leaning it over.less mess less work.if the oil stinks like burnt coffee tho,from the clutchyou proly should put it in yer lawen-mower next oilchange
datadavid said:That small variations in comp can be disregarded i think. How about you put some fuel system cleaner in the tank and just ride the shit out of it?
Redline has a good product, i use it for all my machines.
Cleaned out the carbs on my 750 to a near optimum performance.
And its a lot more fun cleaning carbs while you ride!
xb33bsa said:yer good therehad you tried swapping coils to eliminate that a coil or plug lead is the problem ?
treitz said:Plan is to shoot some compressed air through from the air screw opening and see if I can blast the plug out.
Any other thoughts??
Tune-A-Fish said:Just don't jam anything in the bore... Goof Off works good to eat through stubborn varnish just drip it in with a small chunk of drain tube, if it's really tough use a chunk of mono fill 20# or so to poke at it.
treitz said:The carbs are off... so I guess I could just throw them in the sink with super hot water running into that pilot screw opening. Our sink puts out near boiling point hot water.
treitz said:Yikes! I don't think we have those over here... at least I've never seen one.
