treitz
Over 1,000 Posts
Got it! Got the cover off, and of course I don't have a feeler gauge that goes small enough
mine only goes to .203 mm and the inlet valve is suppose to be .11mm. Ugh
Question... Now that I've removed the valve cover, do I need to replace the gasket?
Edit: While I was at it, I went ahead and checked the exhaust valve clearance. It's suppose to be set to .21mm and my smallest gauge is .203mm. #1 cylinder - it would slide in at all. #2 and #3, it would slide in. Not freely, but it would slide in. Could this possibly be my issue!? #1 running rich because the exhaust valve isn't opening enough!?
I ran the bike briefly before doing this test and at idle, it was obvious that #2 and 3 were running much better/smoother than #1. #1 was inconsistent and typical symptoms of running rich. I checked the plugs and it was already black after idling for 1-3 minutes.
