XS850 - Wiring...
treitz
Over 1,000 Posts
Okay, so I am simplifying the wiring harness on my XS850 and have only come across ONE wire that is baffling me. I've searched and searched and looked at multiple diagrams and I can't figure it out.
These are three wires that go to the ignition switch. However coming out of the connector is another red wire with a female connecter. I have NO idea what this did, or should connect to.
Attached is a picture of the wire, and another picture of a color coded wiring diagram for reference. The left side of the connector goes to the ignition while the right side goes to the harness.
Any thoughts?
May be headlight cutout?
You're lucky, i had a ton of useless and broken wiring on my 750, took me weeks to patch it all up to something near reliability!
Use a multimeter to find out if/when the spare wire has power and you'll be a good way toward figuring out what it's for.
Thanks for the suggestion. I double check the red wiring circuit and it appears to all be correct and intact. The weird thing is that because it is is on the wiring harness side of the red circuit, it should have power all of the time.
Quite possible. It may be that a PO added it for an electronic speedo/tach or something like that.
For sure, pretty lucky. The harness is in pretty good shape. However with all of my electrical component relocation, and am pretty much cutting the entire thing up to remove extra wire. Not too fun.
Quite possibly. I am going to need to add a battery tender for my iPhone speedometer... so I'll plan on using it for that.
If that wire was in the headlight bucket, it could be there for running lights. An optional fairing would have running lights and require a power source. JAT
