XS850 with 2002 R1 forks: Which spring rate?
roadracer28
I am currently building a street café racer.
The bike is a 1980 Yamaha XS850 and Im using fork+ single shock from a 2002 Yamaha R1.
The single R1 rear shock (stock spring) uses the OEM profile and stance position.
The R1 forks are much shorter than the OEM XS850 forks ( with stroke of 120mm vs 175mm) + the XS is much heavier.
With the preload adjusters set to max, the front end uses about 60mm in sag from fully extended (no rider on bike).
XS850 wet weight: 568lbs
R1 wet weight: 430lbs
I weigh 175lbs w/out gear and using RTech spring calc 1.16 is recommended on the R1 fork (using the 568lbs of the XS).
Im leaning towards a 1.2 because of the shorter fork will push more weight to the front of the bike.
Solid thinking or other thoughts?
Thanks,
Andrew
I went with the RaceTech FRK SPR 38x36x250 1.20 kg
It's a stiffer spring but it made a huge difference in the ride. The stock springs were really sloppy. The new springs gave it better pop out of corners and made for much smoother stopping. I had my local shop adjust the preload and ride height with me on the bike.
Let me know if you need more details.
