Hello ladies and gents. I'm here hoping to join in with the best of all you and soak in your knowledge of building cafes. This will be my third motorcycle; first ground up/rebuild. I'm coming from 15 years of wrenching on cars of the European variety. The idea behind this thread is to get insight from those who have been there done that and help me sift through all the reading and planning I've been doing, as well as keep a log on the progress. I've never been one to a build thread with any of my projects so we will see how this goes.... it might just turn into my dumping ground for questions if that is alright.
1991 VW Jetta GLI VR6 motor swap:
Mk2 Jetta Vr6
The virago has proven to be a good find - a 920R chain drive than runs great. I've owned it nearly 2 years, put about 50 miles on it before I put it up on the table for disassembly last fall. I've been collecting parts ever since. I'll get photos up when photobucket is not having issues:
Parts so far:
Binelli tank in excellent shape
MotoLana seat
Subframe
06 R6 front
R6 to XV920 steering stem
Headlamp
Yet to buy:
Proper hub to convert to spoke in rear
Rear shock
clip-ons and other front end bits - levers, master, etc etc
Front hub to convert to spoke - Cognito is an option
anti gravity battery
Hub/spokes/tires
Yet to do:
Finish tear down
Prep motor for repaint
Rebuild carbs
Rebuild starter - upgrade to xv1100?
reassemble/test fit
modify tank/frame
modify subframe
to the paint booth
reassemble.
I've been reading a lot of other threads on this website, viragotech, caferacer.net etc. related to these conversions and I'm still looking for answers to two main components to this build:
What hub to use for the chain drive spoked hub conversion. I've seen 86 XV535 used for shafties, but can't find others that have converted chain. Is there a known thread that tackles this conversion?
Importance on fixing the fork offset on doing the front end conversion
...I'm down the rabbit hole with the front end conversion. I'm starting to read on rake and trail and how the R6 conversion does change the geometry. I see Cognito sells triples that fix the issue. Can anyone who has done this conversion shed light on the matter?
Looking forward to finally be able to spend time on this machine and get things sorted over the winter for 2017.
Mk2 Jetta Vr6The virago has proven to be a good find - a 920R chain drive than runs great. I've owned it nearly 2 years, put about 50 miles on it before I put it up on the table for disassembly last fall. I've been collecting parts ever since. I'll get photos up when photobucket is not having issues:
Parts so far:
MotoLana seat
Subframe
06 R6 front
Headlamp
Yet to buy:
Rear shock
Hub/spokes/tires
Yet to do:
Finish tear down
Rebuild carbs
reassemble/test fit
modify tank/frame
modify subframe
to the paint booth
reassemble.
