Yam RD E-Dead
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
so here´s the story...i totally tore down the bike, a 1979 Yam RD (the one with elect. ignition).
now i´m in the phase where i put everything together to see whats missing/not working.
when i bought the bike the electrics were running fine,besides the blinker relais was missing,bought a new LED relais and installed it (3 points).
now i bought a completely new gel battery with 6 AH and 12 V connected it to the loom, all plugs connected....idiot lights and horn not working...she´s dead...
the headlight is not installed yet...maybe thats the reason?
bought a multimeter but i dont know where to start....
thanks in advance for any help!!
Fuse(s), ignition switch, or any of the wires leading to/from those things would cause your problem. Time to check for continuity.
thanks sonreir! in which order would you check the system?
thanks for your wisdom!!!
I know that my CB160 is not grounded until the headlight rim is installed on the bucket. My DS7 is not like that but it might not hurt to put it back in and give it a try.
ok i finally got the headlight and horn working....found out that the - cable of the battery and the conneciton with the frame was bad...cleaned and sanded a little bit the connection with the frame...connected the headlight to the loom (no bucket just the sealed h4 light assembly) and boom horn and headlight worked...
but i dont get the blinkers to work.
i replaced the original 3 point relais with an LED relais.
there are 2 cables for the blinkers in the headligt bucket.one with a round connector with a hole in it (i guess -) and connector to plug the + into.
my new LED blinkers have a plus and a minus plug connector.how would you guys connect them with the loom to work properly?
