Yamaha 2 stroke
Yes, I love the floors in my apartment! Can you believe some asshole put linoleum tile over those in my kitchen area?!
Cierrecat, I have tried everything possible, already have a mity vac too, no luck. Tried backwards bleeding with a syringe...the pistons will not move. I hooked my master up to a sv650 cylinder that is the same configuration as our RD's and after 2 minutes of bleeding there was stiff lever and the pistons move in and out. My rebuilt caliper did not leak anywhere. So, I took it back apart...basically the new seals are super tight. I used an air compressor to get the pistons out the first time I stripped it and it took about 5 seconds to push them out. I tried for 15 minutes to push them out with the new seals...really took forever...and when they finally popped out, I was very glad there was a towel under my hand...they shot off like rockets. Could not push them back in by hand.
Seals should not fit THAT tight. So I emailed HVC and they told me to make sure I cleaned out the little grooves(which I did the first time). So I will try again. Frame and battery box mods are complete...still waiting on my welder to finish the oil tank ...a vintage smoke Dyna ignition should be here next week...and I am dropping my frame swinger and brackets off to be powdercoated next week. I was going to just have everything blasted and then PJ1 rattle can...but they quoted me $250 for blasting and gloss black powder...for like $100 just for blasting...so I'm going for it...fuck it why not. I have been funding most of this by selling nice stock parts and ebaying random form garages sales and thrift stores! Will post a pic of a pair of vintage AGV helmets I found at a Goodwill store for $6...on ebay now...should make a nice profit as they are already bid up to $160.
did you check that the crush washers were sealed? i spent about 10 minutes bleeding brakes on my dads ride before i realized that the crush washer wasnt totally... crushed... :D
They were tight, I get fluid flow no problem...no leaks. The whole setup works with another caliper. Sometihing is up with my seals...and they cost $45 fucking dollars...ridic.
Here's those vintage AGV helmets...his and hers still, have name tags on them from the owners, "Royce" & "Lynn" haha. I think they are from the 70's...sorta want to keep them but I need funds for my smoking habit hehe
My modified battery box, it sits about 2.5 inches lower to make way for my seat(if I ever finish it-taking forever!)
new y boot with k&n filter
welded in threaded inserts...because I need my front seat mount to be removable.
rear seat mount
That sucks about the seals. I bought and installed the cheaper $18 versions from MikesXS and they seem to be working great. Took a little effort to get the pistons back in, but I lubed them up with brake fluid and they were fine. My problem now is that I think I put the pistons in backwards. I have the flat part pushing on the pads, and i think they were supposed to go the other way. Not sure it matters though as they seem to working perfectly. :-\
Nice progress otherwise man!
Yea, you got em in backwards, I would take the time and correct them. I looked on mikesxs before and the seals looked totally different than mine...so I thought they wouldn't work? Maybe I'll try them instead.
Damn this is clean... the carby boot is great, and the oil tank is freakin' outta-this-world!
Keep up the good stuff man - boingk
Time to clean this lump up...need to get to work scrubbing so I can repaint the cases. The cylinders and heads are being blasted with aluminum oxide while my frame etc. is being powdered, because it's just impossible to get in between all those fins. Making some little progress...I polished the carb slide covers and got ahold of some bronze swingarm bushings.
...wish I knew how to use my damn camera, sorry the pics suck.
Oh, and a cool yard sale find...$3.50 apiece! Cool looking lids.
98% finished with my seat plug. Still needs a few spots puttied and final sanding/polishing/waxing before fiberglassing. I am quite pleased, it isn't perfect but close enough for me!
Also, came up with an idea for the oil tank. I think it would be cool to strip the paint and clear coat the raw steel...then add some racey decals.
;D Now were talkin! Psyched on how the powdercoating turned out...so worth it. Also had my top end blasted...cleaned them up and have started repaint. pics:
Hoping to get the bushings pressed in the swingarm tomorrow so I can start assembling the chassis! I know I'm going to want to replace every bolt now to be up to par with the frame... dig in them pockets some more...
What's up with the crank and jugs?
I'm rebuilding the RD400's engine as well. What did a rebore cost you?
--Thanks, Chris
Hey Chris, I am still in the communication process with Scott at SCR Racing in Portland, OR http://home.earthlink.net/~scloughn/index.html . He's a 2 stroke specialist with years of vintage Yamaha experience. I am splitting the cases tonite and sending the crank and jugs off to him. He checks tolerances and advises on what needs performed. Basically, labor for a full crank rebuild is $100, parts is another story...typically it's around $300-$400 for our bikes...however, from what he told me not everything necessarily needs replaced and OEM is not always best either. I believe that the 400 conrods are harder to find and cost more than the 350. Pro-X conrod kits are supposed to better because the bearings are silver lined instead of bronze or brass or whatever. Plus they are lighter. I may have him balance mine as well depending on the cost.
For the boring cost I would estimate it around $70 per cylinder...plus $200 for the piston kit off ebay. On some of the 2 stroke forums, his port work gets nothing but high praise. I may also have my heads recut as it is really not too expensive, and matching the squish bands really improves our motors. I'm going kinda overboard and dropping some serious coin, but if something's worth doing it's worth doing right!
Made my first seat...I think it looks pretty awesome....definitely real 70's ahaha. The mold worked beautifully.
lil update...sorry for crappy quality of pics:
Seat mounted properly. I put some rubber foam weather stripping on the bottom where it rests on the frame. Up front I just used button head allen bolts with rubber washers under the brass flat washer, and the same on the bottom side. For the back, I had about a 2 inch gap between the bumstop on the seat and the frame mount. So I took a piece of wood and cut it to size, wrapped it in the rubber foam stuff and then drilled 2 big holes through the seat, wood block and frame mount. Then I used 2 3 inch carriage bolts to secure it all. Pretty much anywhere the seat touches anything there is rubber dampening. Still working on a taillight and plate mount...should be simple.
Then I made a seat pan and trimmed it to size. I have a friend who is a clothing maker and quite handy with a sewing machine...now just to find proper foam.
And I couldn't resist a mock up with the engine and pipe! Just empty cases and a spare R5 head...mine are on their way to SCR racing :thumbsup:
-blasted, cleaned, painted
-everything is being meticulously cleaned and reassembled
-all oem bearings rods. SCR balanced and welded the crank as well as rebuilding it!
I finally have a proper workspace!
mmm, so much good stuff in this thread! im surprised i missed it until now! ;D
