Yamaha RD battery eliminator
ringading
Hey guys!
I've been tooling around a little bit on my 1975 RD250. I'm looking to eliminate my side covers by installing a round oil tank and eliminating the battery all for that clean look. Is there a way to eliminate the battery from the bike? a different ignition system? Is there a way to hide battery and run the wiring so its clean? Basically i just want to have open space behind the carburetors. Thanks for any help! :)
Bruce Taylor
If you're running low-draw lights (ie LEDs with electronically actuated flasher unit for the turns) then you could probably just remove it altogether. On the safe side, you can always just find the smallest battery you can. I'm assuming 12 volts here, and the smallest I've seen in that was 1.2Ah, roughly the size of a Mars bar. I'd just use that, very easy to hide.
Cheers - boingk
