Re: Yamaha rd350 road racer
And yeah I meant before assembly as far as the o ring sitting up to high to allow it to register before torqued. I still have the tz groove dimensions you sent me, that's what I'm planning on using.
I'd be happy to machine some for you once I make sure I don't scrap these ones.teazer said:Nice work. I may have to send a set of heads for you to machine for me...
Should be zero. If not, it won't seal properly.
Exactly lol ill measure today.jpmobius said:Indeed! to clarify, I was meaning the distance the ring sits proud of the groove with the head off. I guess easy enough to know by subtracting the groove depth from the ring dia.
That one is actually just the fairly cheap spi. I've used to to build several progressive stamping dies. If it's good enough for that is good enough for use on the old south bend lol.irk miller said:I need that test indicator. You and your fancy measuring devices. 8)
Any possible way you could contact that customer and see if he still has the bike and how they are holding up?Shoeman said:Fantastic discussion gentlemen. All I'll add is that I worked on a set of the India made cylinders back in 2010 for a customer and one of the sleeves was offset to the port castings by several mm. I can't recall just how much, and the porting requested took care of the issue anyways. QC may have improved since then though. Oh, and they shipped two left cylinders initially. Oops.
