Ye Olde Rd400
LOL sign me up, I need to find one of these to play with too. then I can build a trailer like Troy and tow it to all the GTG's behind the GL ;D
clem said:
I agree it is a simple task. I just said screw it and sent my crank off that way it was one less thing to deal with later.
Do you have it back together yet? I mean it's been days since it's been torn down. Ha!
Well in a perfect world ;)
But funds are tight for projects at the moment, you guys should all buy some seat hoops to help fund a crank rebuild.
Kickstarter? Hahaha
Reassembly this weekend
If only I could find the key that I lost within 2 minutes of bringing it home
I'm sure you probably know but Justin Longhorn pointed me in the direction of an Ebay seller that can make a good key for those old ignitions with just a few numbers off of the back of the ignition switch. Just an option in the even the key stays hidden.
Mind posting a link?
More than likely I will be removing all that junk anyway, I always wire my bikes as simply as possible but this one may get the restore treatment, depends on how I feel after I ride it 8)
With some help from Justin I found it on Ebay again.
http://www.ebay.com/itm/Yamaha-Kawasaki-Suzuki-Honda-Keys-Cut-by-Code-Number-/390227950248?pt=Motorcycles_Parts_Accessories&hash=item5adb65faa8&vxp=mtr#ht_3519wt_713
is there a chance that you make a step by step engine oil seal to-do?
bradj and everybody says to exchange these seals when an rd wasnt ridden in years....mine wasnt so ive got to to this change!!and i´m shiiting my pantz...
Well I would, But I already tore the engine apart.
Shoot me a PM and I can walk you through the whole process, its really simple.
If you want I can shoot some pictures as I reinstall so you have some reference
Got the engine back together and in the frame.
After a bit of frustration and starting fluid it runs!
But only on the right cylinder.
Also had a bit of a scare earlier.
"Dieseling" or runaway.
Bike was idling/revving for a while while I was playing with the carbs trying to get right cylinder to fire. All of a sudden the Rpms shot up to 9k.
Well shit I say to myself as I flip the kill switch.
Nothing
Damn kill switch quit working I say, kill the main power.
Nothing.
At this point I stood and looked at it revving to oblivion and thought "I need to back the fuck up before This thing explodes"
Thankfully I had the presence of mind after a second or two to flood it out with the choke.
Any ideas what will cause this? I know it's fairly common with 2 strokes but it's my first encounter with it.
Stock airbox, no air leaks, stock carbs, stock jets.
No exhaust gaskets at the moment which is the only thing I can think of, but I don't see how that could cause a runaway?
