yet another CB360 running issue
bissinger
every time i start the bike up, it will run fine for a few seconds and then just bog down and die. Over and over it does this and I am perplexed.
Try adjusting the idle screw, and make sure your air intake is stock with no holes or gaps in it. Hopefully you know how to work a choke as well.
Let me know if all that is fine, you might have fuel problems or mixture problems.
i battled those symptoms for weeks. it came down to the petcock not flowing correctly. i had cleaned it once so i ruled it out and tried everything else three times. took it off blew some air through it and ive had 300 trouble free miles.
yeah, im pretty seasoned using a choke.
ill try the idle screw, although i wasnt sure if it was the idle becuase it would just bog down, felt like it was something different.
and the petcock is brandy new. Maybe i need to coat the tank? Im thinking it's something carb related and it seems like checking the airbox/filter would be a good start thank you.
