Yet another Honda CL350...
danielsb
I've always been interested in bikes, but up until now, I've never had the chance to own one - frankly my desire to buy was fizzling as I got older. Fortunately, my passion was stoked when my friend drove his Yamaha XS650 to work one day; and well, the rest is history... kind of.
Once I decided to buy a bike, and did a bit searching, I came up with a list of soft specs to look for in my first bike: low cost, simple, and small yet capable of occasionally commuting to work. So when I came across this 1971 Honda CL350 on ol' Craigslist, I bought it. The engine was seized and the last owner hadn't started it in years, but it seemed to be complete, and a good starting point for a project build.
My attempt with this page is to document the process, ask question, and hopefully be yet another reference for those building their own Honda 350 projects.
I recently rebuilt a CB350 engine that was seized up. Figure these things (and I'll surely forget plenty) First, you'll want to get a shop manual. The Honda manual, although still vague in places, is the best bet. Then, an impact driver to bust loose all the soft, stripped screw heads you'll surely encounter. You'll want to have the head checked out by a good machine shop. Make sure the valves seal, and aren't bent, the guides are within spec, and that it isn't warped or cracked, and all that good stuff. I had to put valves in mine, (which were not cheap), a valve job, and a resurface. The cylinders on mine were too rough and had to be bored, and new pistons and rings fitted. You'll probably need the same. Every one of these engines needs a cam chain tensioner, and you might as well upgrade to one like a "KA Slipper". In my opinion, if you're going this far, you might as well split the cases. Make sure everything is in order, and replace the cam chain. At this point you can get the cases thoroughly cleaned, they'd probably appreciate it after all these years. On the outside, you'll need to rebuild the carbs, and the points system (or upgrade it to electronic) You'll need a gasket set, all the little miscellaneous oil seals, miscellaneous hardware, and anything you come across that is damaged, missing, or that you lose (all of which will happen) As a rough figure, I probably spent at least $900 making my engine like new with the couple upgrades I mentioned. Then...theres everything else on the bike :o
ADC - All projects are bound by limits, be it time, money, or knowledge; and although this is my first bike, I am very comfortable wrenching, fabricating, and finishing. I think we would both agree that it is wise to know your own limits, but in my experience, one learns most when he or she tackles a project that is new or unfamiliar.
Madmatt1 - I think you’re spot on! In my initial post, I forgot to mention where I’m currently at within the build process. I’ve completely disassembled the bike and am now in the middle of prepping the engine for reassembly. My next couple of posts will detail disassembly and rebuilding the engine.
Disassembly:
This was a fun process and the bike was fully disassembled in a relatively short amount of time. It also helped get a better understanding of how the all of the various components worked together and what would need to be repaired or replaced.
A couple thoughts for disassembling; mostly all common sense but can be easily forgotten in the moment:
• Take your time. Try to understand why the bike was put together the way it was.
• Take pictures. While I was wrenching away, I just wanted to get the bike apart so I could get to the next step in the build. I took a few pictures of what I thought would be complicated during reassembly, but I wish I would have taken more.
• Label and bag parts. This will save time, money, and headaches.
• Make notes. Knowing what parts will need to be replaced or repaired can help better plan for time and money.
As a side note, I would have preferred to have ridden the bike is for a couple months before doing any serious modifications, but based on the condition of the engine and the time of year it made more sense to start right into building what I set out to – a café racer/brat.
Cool. Too many first time builders get in way over their heads with no previous experience or skill, and think that they can be Jessie Fuckin' James with their new toolbox and a hacksaw. :)
If you are in Grand Rapids feel free to swing by. I am always happy to meet people from the area.
I also have quite a few parts if you need any.
Sounds good Dalovva - I wouldn't mind picking your brain too. I took a look at your bike build and it's got a lot of the aspects I'm hoping to add to my own...
