Your Build - In Pictures
Sonreir
Oregon
DTT SUPPORTER
OK ladies and gents...
I ended up doing this on the DWMS forums because I wanted to get my build thread up over there and instead of feeling like a shortcut, it actually had a certain magic to it. The idea is that you post your completed build from start to finish using only pictures. No comments or texts allowed except for a single introduction paragraph located before the pictures.
Please, let's keep this thread clear of chatter, banter, and superfluous remarks. Bike content only. Comment in the user's build thread if you have questions.
Performance work done to date:
*+2mm bore for total displacement of 378cc
*Custom made, high compression forged pistons (running at 11.1:1 static compression)
*Megacycle cam (+21° duration and +.040" lift)
*RD valve springs
*Racing clutch springs
*+1mm oversize, backcut, Kibblewhite valves (intake and exhaust)
*3 angle grind and .020" skimmed from the head
*Mild port work (mainly a cleanup of the casting marks, no enlargement or polish)
*Casting marks removed from rocker arms resulting in 5g weight savings for each arm
*Bronze valve guides
*Copper head gasket (.032" thickness)
*Dry weight reduced from 357lbs (stock) to 284lbs
Estimated power to be 40hp measured at the rear wheel. I plan to dyno it after I get the tuning better. If this is correct, the power to weight ratio matches that of a new Musting GT.
Build thread link is in my signature and there will be more to come as the years roll on by...
