Your typical CB360 build.
  • Thread starter Thread starter SAL
  • Start date Start date
S
SAL
Guest
Allright everyone, i've been lurking this board for days now, learning everything that i can from your builds and advice. Since i'm now several weeks into the project and feel like i practically know everyone here anyways, i figured it was time to just bite the bullet and start my own project thread and see how you might be able to help me out. Anyways, here goes:
So, i've wanted a bike for years and finally decided to do something about it. After scouring the internet and newspapers for days i found a '74 360 on craigslist for $100. Given it's condition, i'm not sure if it was exactly a steal. It was last registered here in texas in '90 according to the sticker, and looked as if it had been sitting outside since then. Lots of rust, thankfully nothing very deep, and moss starting to grow on the engine case...
It took 4 guys to lift it in the back of my suburban, and i couldn't get it out by myself once i got home, so i started tearing it down inside the back until it was light enough to move on my own. Thus, no before pictures, but i have these after i started to tear it down and begin the cleaning process:
The engine needed/needs a LOT of cleaning and polishing. It's getting there slowly. I plan on painting the case, polshing the rest. (save for the fins, which will be blasted and left matt... i think) I have four brand new rocker arms on the way (old ones were really worn) and looking about for a new cam. Going to pull the valves this weekend and check the guide clearances and seats.
Went ahead and painted the frame before deciding (after many hours spent on this board) to go ahead and actually change some things about the frame. Also just roughed out a black stripe to try out the look. Now it looks like this. Also got that benelli tank mounted up and ready to go:
After i make some decisions about how/what to do about the seat, then i can weld up the tail hoop at the proper length and get going on prep for paint.
i plan to do the usual, cropped tail, clean all the tabs mounts and miscellanious junk, clip ons, cafe seat, rear sets, wrapped exhaust, etc etc. plan is to have it done by the end of summer so i can take it back to california with me when i go back to school.
Thoughts and advice are appreciated. I already know you guys are phenomenal from all the threads i've already read.
-Alec
I've actually considered this. It was actually your build that inspired me to look for a benelli tank. Unfortunately I just don't want the bike to be JUST like yours... But i may be interested nevertheless.
I have a new style seat that I actually like much better. I have six seats in stock that I'm sending to Go! this weekend to get covered. PM me if you're interested.
--Chris
So i spent the evening painting the main case and getting the crankcase sidecovers all polished up and shiny. ;D Yesterday i took the tank back down to bare metal and primed it with an etching primer, i'll give it a few more coats over the next few days and let it harden until next week sometime before doing the first color coat.
In the mail now are new front fork tubes, a stainless engine bolt kit, and a NOS cam to go along with the new rocker arms i received yesterday, so i shortly should be ready to go on finishing the engine build.
Anybody have any advice as to what to do about blocking off the starter motor hole? i'm planning on going kickstart only. Also what about the cylinders/heads? I'm not sure what to do about them past media blasting them...
For a starter blockoff, contact kit@dropbars.com. He has the most elegant solution on the market. I forget what he charges, nut is was way too little for what you get.
--Chris
Tore it down in the back of the truck to get it out of the truck. I love it! :) Did you just buy that tank on ebay a few weeks ago? I almost bid on that. Looks good so far. I'm ready to paint a frame, what did you do to that one?
Haha, you do what you gotta do man!
Yeah, i got the tank about 2 weeks ago on ebay. I really like the look. As for the frame, I cut all the tabs off for pretty much everything but the engine mounts and the rear footpegs, which i'll use to instal rearsets at some point. Also cut the tail, and welded up a bunch of seams that the factory left. I welded some plate in under the seat so i could put electrics there, but i didn't like the result, so i cut it out and am going to try hammer welding it in this weekend.
That's about it. I'm not sure i'm confident enough to be cutting up the frame too much more than that at this early stage in my cycle career.
I know what you mean, anything I cut out other than a tab I'm looking to relpace it with some thing that at least "looks" stronger. I'm watching these builds a lot and copying.
Looking good. I need to get moving on my R5 build.
yeah, to be honest i wasn't even going to touch the frame until i started reading up around here and it got me thinking about what i actually could do.
funny you ask this, im currently fabbing out a disc/ faux gear to block off the starter housing for my 360. granted mine will look nothing like mysta2's product. (his stuff is premo!) might i suggest also trolling around CL again... get yourself a POS 360 lump.... its been real nice to be able to tear into and use as a guinea pig for whatever i have to throw at it, or to try something new. mine even runs, i just made a quick mount out of some tube steel and bolted it in. i even use a coffee can for the gasoline :-[ haha talk about ghetto.
did you come up with your own trick for the cover?
I went ahead and emailed the fellow chrisf reccomended for the cover. Eventually i'll turn out my own plate, but i won't have access to my machine shop until late august when i go back to california, and i needed a solution prior to that. I figure I'll get the frame/tank/fender all painted up and shiny, and get the motor internals done to get a solid running bike so that once i have access to a lathe/mill, i can take my time and work out all the other little issues.
Good idea on the test bed engine, i just don't it would be practical given my budget and how far i've already come on the motor i have. nice work with the coffee can. :P
The benefit of the 360 is that it already has a pretty beefed up frame compared to the 350. The only thing I've done to my frame is to shave and weld the pressed and spot-welded spine and finish welding all the partial factory welds. I may or may not add a swing arm brace depending on how motivated I get, but that's pretty much it. Some people also add a horizontal brace between the "intermediate tubes" on either side of the carbs and the rear shock mount tubes but that's probably overkill.
Yeah i really didn't like how they left so many seams unwelded. I guess it's faster/cheaper for them, and I'm sure it works just fine, but it's just another detail that can clean up a bike.
What did you mean about the swingarm brace? How are you planning on bracing it, and what would the benefit be?
This is a swingarm brace:
The benefit is the same as any bracing done to the frame: to reduce deflection during cornering. The frame and components want to bend sideways under load. Typically this happens at the swing arm bushings which is why they get replaced with solid bushings. The next place to deflect on a CB360 is the swingarm itself, since the frame is already adequately braced, IMO. Adding the underslung brace keeps it stiff.
that's pretty slick. I'll have to keep that in consideration... and the solid bushings.
alright, update time.
I've spent almost all of the last week when i'm not at work with a welding torch, learning the craft so that i might hack together some kind of a passable seat. Nothing too exciting to report there, however, i've got an engine case that's starting to look pretty snazzy, and i got in my NOS rocker arms and cam:
lot's more part in the mail and such. Don't expect to get to much done this weekend, have to do the UV joints on the truck instead :(
