Z1 Enterprises Ignition Coil's?
helitaiwan963
Hey guys,
I'm new to the whole motorcycle scene and starting to work on my 1st bike. '73 CL350 that I'm working on making a bobber. Anyway, I want to replace the coils and wires on the bike since I have no idea when they last been changed...
http://www.z1enterprises.com/Ignition-Coil--Universal--12-Volt-4139.aspx
I was just searching around for some cheap coils to replace my original ones with, being a college student, There's no way i can spend the money on some Dyna ones, but those are down the road... I just want to get the bike running right now, then worry about luxuries after I know the bike runs.
Then I want to buy these wires:
http://www.z1enterprises.com/Dyna-Ignition-Wires--7mm-copper-core-black-208.aspx
I would just like to know how Z1 is and if they're reliable and if i get my items fast. Should there be something else I should be looking to replace in the ignition system while i'm at it?
Thanks
Eric
Z1 has been around for a long time and is a well run shop. I've bought stuff from them myself over the years. I'd say in general if they're selling something, it's OK.
Give them a shout and explain what you're planning, and they'll point you in the right direction. Those coils look OK. Some people run VW coils too I think. Lots of options out there but those look like a good economical choice.
All that being said, what's wrong with your current coils?
Thanks for your response! Puts me at ease of mind for ordering from them.
Anyway, I just purchased the bike this past weekend and purchased it for 300 bucks as a non running, but titled bike. I knew it was gonna need some work. Got a carb rebuild kit and the correct main jet for my build cuz i wanna run pods, got a petcock rebuild kit as well. As I was going through the bike some more yesterday, I found that one of the boots that go on the spark plug is completely broken off the spark plug wire. I then noticed I had one coil that had been replaced already and one was the original coil... They're old and dirty and I figure I would replace them to make sure everything is good so I'm not waiting and chasing down possiblities when/if I start my bike. I'm just eliminating any possibilies so I can replace them while the bike is taken apart.
Also, being a '73 CL350, do I need to have a battery hooked up in order to start the bike? Or will I be able to get spark to the motor from kickstarting the bike?
Thanks
Eric
Needs a fully charged battery for sure. Only bikes that will start without a battery have a Permanent Magnet Alternator (PMA) on them which generates enough juice kicking it over to fire the plugs.
Get a decent battery and a battery maintainer - pretty important especially while you're working on getting the bike running.
If you've got money to spend the new lithium batteries are getting good feedback. I just got a Shorai for my XS650. Very light and tiny. If you're sticking with stock location etc. then a standard AGM battery would do.
Thanks for the great info. After these maintenance items are purchased, next on the list is a good battery and good trickle charger for it.
-Eric
Batteries are cheap and the charging systems on these bikes is archaic. They will fry a lithum based battery, its been shown on DTT. If you want to run one you will need to upgrade at least the regulator.
I'm running those exact same coils on my 360 and they work better than the stockers did and will put out MORE than the stockers will new. I've been running them for over a year and 5000 miles and I haven't had any issues with the bike starting due to low spark. Buy them and don't look back. They will fit in the stock location if you make a bracket for them. IF you are making a BOBBER, consider polishing the cases on them and mount them so that you can show them off. ;) Cases are unfinished aluminum and should shine up nicely.
Just want to throw up another positive comment on Z-1. Good bunch and their customer service it top notch.
As already mentioned give them a call and explain what you got. The will recommend the right coils.
That's what I was hoping to hear! Someone who has tried those exact coils! I ordered them yesterday! Made the mistake on my billing address and the order didn't go through, so I fixed it and the order went through... but my account was charged twice :( Hope to figure that out asap... Got a tracking number for 1 of the orders though already!
And thanks for the idea on the polishing part! I think i will end up taking the time to put in some elbow grease for that. And I don't think i was planning on running the lithium batteries... A little out of the budget range... Stinking college student budget :-[
Hoosierdaddy: thanks for the extra peace of mind! I hope i can get the charged twice thing fixed soon.
-Eric
