tWistedWheelz
BUILT NOT BOUGHT!
Ok, per request I am going to try to explain how to make a home made baffle. I have made one set before and it was using a slightly different design than this, but this is a better method, more simplified in construction.
Materials needed:
1. Copper end caps (x2)
2. Copper pipe (six inches long max) (x2)
3. Copper brazing/soldering rod (I like 15%)
4. Small sheet metal screw (x2)
5. Heavy duty Steel Wool
Tools needed:
1. Torch
2. Drill bit the diameter of you center tube
3. Drill bit in ¼ inch diameter and a 1/8 inch may be required for tuning
I am sorry I have no pics of my construction (this was done before I was a DTT member and did not share any of my work on a computer at all), but I made a figure to use as aid in explaining in MS paint. Refer to each numbered section as I descried my method.
The diameter of your end cap will be determined by the inside diameter of your pipes, get as close as you can and then you can shim a bit with steel wool.
The Diameter of your center tube will determine how much you will restrict sound and flow, you will have to use your own judgment here, but about half the diameter of the pipe is a good start, and then decide if you want more or less. Larger center tube results in louder sound.
Section one shows orientation of components, with caps facing away from each other.
Section 2 shows were to drill wholes, both sizes. More holes = more flow = less back pressure.
Section three shows where to weld, leave some lip on the inside of each cap at each end.
Section 4 depicts where to use steel wool and where the screw should go through your pipe and into the baffle flange. More steel wool = less flow through baffle chamber = more back pressure and louder sound.
Tune the baffle by installing and running your motor, if it needs opening more drill a couple holes in the outside flange end. If it needs more, drill more.
Its that simple. I hope this helps!
Cheers and good luck!
Materials needed:
Tools needed:
1. Torch
