JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Received the new steering bearings today... and got to work: Pics to follow.
Froze then hammered in the races (with a bearing driver).
Took the stem into my buddy's work (Suzuki) and pressed in the bearing...
Now I'm back to having a front end, with fresh new bearings.
So, now it's safe to ride (albeit not assembled). Time to get everything buttoned up...
Bike it looking great Evan. Nice to see you getting the bearings and such done now so no need to worry about them down the road.
I didn't really have a choice! I think the bike has a lot of km's, everything was well-worn.
Considering this fork brace (I previously made it for the SECA but the fender wasn't quite right).
Modified a plastic rear fender that came with the bike to work as an inner fender for my new seat:
Should be completely hidden (from the side) when the bike is complete.
Also threw on the chain guards...
Not exciting, I know... but I like pics.
Fixed and installed the ignition. My key is so warn it won't turn the tumblers, so I had to remove a pin to get it to work.
Back in the stock location.
Anyone know where I can get this type of 2-stroke slip-on pipe?
Front wiring harness and all switches checked and working fine! ...and actually all fit back into the tiny headlight.
New headlight is NOS.
Rear brake switch is cracked, tho... Sourcing one now.
Finally got the bike out for a run in the field, and it's a beast.
Was not fully expecting it to be so powerful but the front tire comes up whenever you want... and the bike still likes to get some air!
After a day of tuning and riding and breaking and fixing things the bike is now fully operational (and street legal-ish). Pumped
Still have to put on the pretty pieces and paint it but here she is in a rideable state.
No Purple Hearts, No Blue Ribbons
That's excellent to hear Evan, glad you had it out for a run.
Well my "new" throttle cable snapped, so I have a new one ordered with a return cable this time... No more riding for a bit.
In the meantime I've fitted the aluminum side-covers just need to get some hardware to attach them. No pics
Rigged up a throttle cable by combining the 2 broken split cable sets.
So glad my next door neighbor is also my test track...
New-New Throttle cable arrived,
So much better than the old ones I'd been using... and still NOS (as is the theme with 90% of this bike).
Also installed the stainless steel exhaust shield and left side panel.
I like the square panels, match the square mirrors and square-ish tank.
Bent side cover to clearance the frame.
Wired up the tail light and threw on the license plate.
The license plate reads Motorcycle Dirt Tracker 77... Not on purpose, but sweet.
Fender installed, new clutch perch, second mirror installed:
Few crashes later and some parts removed... bike crashes well.
Partially due to the tall grass!
LMAO, hopefully nothing too bad or expensive. Quite a track you have there!
Haha. Naw one good high side but the rest was sliding in the grass.
I see you every now and then in the area on your Gladius (I think)
Oh, and nothing expensive or too bad BUT I did lose a bolt in the top tree and that could have ended badly... (luckily caught it just in time)
