1969 CL350 Brat Build
i'll post some more pictures, frame is almost ready for paint. Tank is just about done with getting filled and block sanded. Got my piston rings and waiting for my gasket kit to reassemble to motor!
Frame is painted....BOOM!
Paint has to fully cure 3-4 days, then i'll start building my roller.
The motor is just waiting on my gasket kit and cam chain tensioner rollers then i'll be ready to put the top end back on.
If you are planning to rebuild forks (seals)...I am definitely interested to see many good pics. BTW new correct seals are available from your local honda shop and pretty inexpensive. Also,you can pick up bearings, pads and brake cable from DCC.
I'll take some good pics of the fork rebuild, these are really simple. For seals, I'm using the all balls fork seals. I used them on my 360 and they were really nice.
So do I, looks freaking sweet. I've been trying to sew my own onto a skateboard all week, the results are less than ideal... ::)
Put my bench polisher to work on the top triple tree. Best buy from harbor freight ever!
got the motor painted, now just waiting on a couple item before i can reassemble it
That wheel and buffing compounds are my favorite buys from HF too, they have a bristle wheel that takes off paint like a champ and is really useful
I tried the harbor freight polish and ended up with some from lowes. I wet sanded the triple with some 320 grit then did the aggressive compound and then the finer compound. It's not perfect but i'm happy with it. This bike is being build to be riden.
MatthiasSalzburg said:
Are you using Harbor Freight polish compound as well? Did you sand that upper triple before polishing?
My 69 CL350 fork lowers have phillips head bolts holding them together, did your have the same...or allen heads? If they were phillips...were they tough to unscrew? It looks like the PO tried on mine...didnt strip heads completely. but they arent pretty. I dont know if he gave up or got em popped free. I am assuming gave up, before he messed em up to much. thats the thing that worries me about trying.
BTW polish looks great!
Mine had phillips. I had to use an impact driver to get them loose. Once loose i pulled the fork seal c clip and was able to pull the upper leg out of the lower. Seemed that the cclip actually held the legs together and not the bottom screw. This threw me as its backwards to what im used to
thanks bud, thats a confidence booster for me.
