o1marc said:
kimjay said:Filter don't solve rust in the tank, check your carbs after putting filter on it and i'll bet you that there will always be crap in your float bowl after some time. I've put brand new filters on and if your tank isn't perfect then it will end up there.
o1marc said:Just realized this may not work. I would have to mount the smaller one higher to keep the outlet below the master. That sucks because the tiny reservoirs can be had for less than $2 and I don't see a side exit one that small. Mounting it high would defeat the purpose of minimalizing the larger one.
Thanks Hillsy, that might just work. It's pretty modern looking but if I get it in Matte Black it will be non conspicuous.hillsy said:These ones look pretty small:
http://www.ebay.com/itm/Universal-Front-Brake-Clutch-Tank-Cylinder-Fluid-Oil-Reservoir-Motorcycle-Orange-/111775224595
Or try a clutch reservoir off a YZF750 or something similar - they are quite a bit smaller than a brake res.
DesmoDog said:Maybe I'm not understanding what you're saying, but if you keep the bottom of the small reservoir at the same level as the bottom of the original you'll be fine. It doesn't matter how low the outlet is, unless the issue is it's hitting something. The hose routing might look hokey but the fluid level won't change between a bottom feed and a side feed.
They keep telling me how adequate the stock TLS brake is, but I just wanted this look. You can't really have too much brakes, just need to know how to use what you have. So far this build identically matches the picture in my head.Brodie said:Well that aught to stop you quick.
Nice work Mark.
