1973 cb500 build
HerrDeacon said:
What size socket did you use? By this I mean, did the socket make contact with the inner ring? If so, you may have damaged it and will need new ones. You should only tap on the outside ring.
I made sure it was only making contact with the outside.
Sent from my SPH-L710 using Tapatalk
I'm not familiar with the 500 hubs, but wondering if the inner collar could be interfering with the movement. It could be off-center and preventing them from moving.
Okay so I have been really bad at updates lately. Hubs and frame have been powder coated satin black. The front hub bearings are still stuck but if I can't fix it I'll just knock them out and spend 20 bucks on new ones and be more careful. I had to paint the lower triple and all of the misc parts like the kickstand, break caliper, and pegs because I'm running out of money and I want this thing done. They turned out good and match the powder well. I just installed both races in the head and should be installing the triple trees tomorrow. Hopefully the engine will be put in tonight so I can mock up the swing arm for my battery mounts to be welded on tomorrow so I can powder the rims and swing arm this week.
Installed races by freezing them and using a piece of flat wood and some pvc I found in my attic. They went right in with a couple hard knocks from a rubber mallet.
the top one sticks out a little but from what I've heard it's supposed to
Painted parts
What a wire wheel on a bench grinder can do in 2 minutes
That bearing race that is sticking out doesn't look right. I would think it is supposed to go down to the seat of the counterbore in the tube. Might want to check on that :)
how hard is it to tell if it is seated ? not hard at all if its right in front of you ::) jeesuz either it is or isn't
can you get a feeler gauge underneath it ?
blow up the picture dufus
the shoulder you see is not the seat
the stock bearing is quite thin and sits near flush
Yeah the all balls races are much taller than the stock ones. It's seated. You can see in this pic that the lip you guys think it should touch is not the one it sits on
Finally got the engine in. Layed it on its side and dropped the frame over it with my dad's help. Almost had a heart attack but it's in and I'm super happy. Now I can mock up the battery mounts on the swing arm and get it welded and sent to powder
something you may be interested in at this stage is a mod that allows you to remove the engine easier in the future. Others will have to chime in as I have never done it and not sures its available for this bike, but im pretty sure a guy made a kit for 750s that replaced the backbone or lower rails to enable easy removal. Just a thought and something to discuss maybe.
I stand corrected. That must be a pretty shallow race on the original. I don't know Hondas so I was assuming ;D
On those frames there are three tubes on top - one can be replaced with a removable tube. This doesn't have a rail that's easily replaced, and the engine is pretty easy to get in and out.
