1973 cb500 build
Painted the top pitted parts of the fork tubes. I've been on spring break for the last week so things will pick up a lot
Sent from my SPH-L710 using Tapatalk
I sanded the top pitted parts down as much as I thought it needed and then cleaned them well with acetone. Let it dry for an hour and then used 4 coats of rustolium. It says it is meant to be sprayed onto bare metal so it should hold up for a while
I also cut off the back tire which I should have done a long time ago
Also trying to strip out the failed creme liner with acetone. Needed a lot more than I thought
Sandblasted many things yesterday to save money before powder coat tomorrow. All he is going to have to do is touch up a few spots so it should save me about 150 bucks total. My girlfriends dad is awesome for letting me do all the blasting in his driveway. Of course I left it cleaner than it was to begin with.
I also bought a red Scotch bright wheel to get a brushed aluminum finish on some engine covers. More pics in a sec
Still a lot of work to do. The grain isn't straight enough and there are some parts that need to be hand sanded because the wheel won't reach them
for the grease broom stick and a few clothes to clean up the bulk. Then switch to brake cleaner and again spray and use a few cloths. Then wash out good with soap and water and re-grease.
How do you pack all balls bearing with grease if they are sealed in both sides?
Okay so I froze the bearings for an hour and used a socket to tap them in. Now the inside ring won't spin on either. What do I do now to not destroy these bearings
What size socket did you use? By this I mean, did the socket make contact with the inner ring (i.e. race)? If so, you may have damaged it and will need new ones. You should only tap on the outer race.
