The Side Panel Paradox. Morally unethical, creatively discombobulating. Good luck with that one Mike.Ha ha... One vote for, one vot against, guess Jim and I cancel each other out.
Woh, there may actually be a split in the Space/Time Continuum. Hang on fellas we could be in for a bumpy ride!The Side Panel Paradox. Morally unethical, creatively discombobulating. Good luck with that one Mike.
Ha, and the inside has already flash rusted. I think I will grab a jug of metal rescue and use that for one last cleannout then just drain it and add wd40 or 2stroke oil immediately. It was all clean bare metal inside. The water rinse to get rid of the viniger flash rusted before it got dry.
Thanks. I have one more rust out to do, going to try metal rescue for the last one and leave it in there for a few days or more. I'll then do the compressed air dry and WD 40 trick.After dumping the vinegar out of the gas tank I rinse with a garden hose then use compressed air to blow out most of the water. After its mostly dry I spray WD-40 inside the tank and use compressed air to get it inside all the nooks and crannies. Being fast with this method has reduced flash rust for me.
