onetruepunk87
downtown809 said:Are these dual caliper forks and do they look like your 1978 CB750 forks or have they been swapped out?
My '77 forks look the same. I had wondered the same thing until saw yours.
But it sure is pretty and looks to be the right vintage style that it should for an early '70's K2 unit.This bike was stripped back and mechanically restored before being fitted
with a new front end and exhaust system,
Very nice Matt, thank you, Petermadmatt1 said:You got em! So I hope that they meet your satisfaction?
Ebay item, and it fit perfectly. http://www.ebay.com/itm/CAFE-RACER-SEAT-FRAME-LOOP-TUBE-HONDA-CB500-CB550-CB750-/181098508398?_trksid=p2047675.m1850&_trkparms=aid%3D333005%26algo%3DRIC.FIT%26ao%3D1%26asc%3D12%26meid%3D6180993733434974432%26pid%3D100011%26prg%3D1005%26rk%3D3%26sd%3D181094720843%26legitmw said:Where did you buy that tube for the seat hoop?
Looks nice one true punk.. I rattle canned the cx500 I was looking to step it up a notch with this build..onetruepunk87 said:Rattle can looks just as good so long as you do it right. I did all the paint on my CM400 by spray can.
Hoosier Daddy said:No shit... the caliper mounts are ambidextrous... well I'll be.
AlphaDogChoppers said:Using air to expel a caliper piston sucks. Not only can it shoot out like a high-speed projectile, often, it simply won't move at all. The ONLY way I do it is to have it connected to the brake line, and use the master cylinder to pressurize it and force the piston out. The master cylinder can produce at least ten times the pressure, but will do it without throwing the piston 30 feet across the room.
On a caliper with multiple pistons, after one starts moving, put a C clamp on it to restrain it so that you can get the other piston moveing. You want all pistons to come out together, because once one piston is out, there is no way to apply pressure to the other one.
