1978 CX500 Build
I've seen some mixed information online on using old Goldwing wheels on a CX500. Can anyone confirm or deny if this is possible?
Main objective would be to use spoked wheels instead of the comstars.
Understand that the goldwing has a disc brake rear instead of drum. Can you use the goldwing swingarm on the cx500?
I have wondered this too. I think someone has done it with adding a caliper mount to the CX swinger but I am not sure if the final drive splines match, it wouldn;t surprise me that they do because Honda tends to re-use anything functional on multiple models so it would make sense the shaft drive bikes would all have the same drive to save $$ in manufacturing.
I've read mixed reviews on whether or not the splines match. Couldn't find any clear step by step builds.
Based on this
http://www.goldwingfacts.com/forums/2-goldwing-technical-forum/286754-looking-alternative-routes.html
Looks like you can run the gl1000 rear end on the cx500.
Still looking for more detailed info.
Interesting.
I've read the same confusing info you have in my search.
I currently have a Virago 535 rear wheel that I am looking into adapting. 5 lug spoke with drum brakes, 15mm axle. It looks close, but the drive gear will take some machining to mate up correctly.
I'd be really curious to see how close a gl1000 rear end would be to working...
I'm thinking I'm going to look for an inexpensive GL1000 rear end and forge ahead. I'll update here if I'm able to find parts for the right price.
well i looked at that post on goldwing facts and it full of it
the gl1000 swingarm will not bolt right on to the cx500 it can be done but it takes some machining welding
and other stuff
then you wind up with a even higher revving cx 500 how useful is that??
you can put a goldwing rim on a cx500 here is one with a 17 inch gl rear wheel and a gl1000 front end and 19 inch wheel i am
just finishing this bike now
it also takes some machining to do but not to bad
cxman, which bike specifically did the GL wheel come off of? GL1000? What kind of machining is needed? Could you post more pictures of the back wheel area?
Doesn't look like I'm going to make it over your way this week. May try to make it when I'm back in the area next month.
the front end and rear wheel are off a 1976 gl 1000
you need to make a tube bushing to match the id of the gl1000 bearings to the od of the cx600 axle you will need
to thin down the gl1000 caliper mount to fit the cx500 swing arm and bush the hole to the cx axle
you will also have to machine a new distance collar for the final drive to match the bearing thrust collar of the gl wheel bearing
you will need to make a caliper stay bracket and weld it to the swing arm
you need to toss the cx500 final drive dust sheild and roll an new one out of sheet metal and attach it to the final drive
i used a piece of stainless sheet metal the cx dust ring goes inyo the wheel and it needs to go over the gl wheel
so it has to be a larger diameter
its raining and cold here i will try to take some pics tomorrow
Very interesting. I'd be curious to know what all it took.
It would appear that the rear caliper/carrier might be a tight squeeze back there.
That's part of the reason I looked into the Virago 535, as it's a drum hub.
Thanks for the info, Murray!
tight squeeze is actually simple to get around
i remove the axle then the 3 bolts that hold the final drive to the swing arm
i take the caliper off the caliper bracket
then i take the whole shebang off it actually just rolls back off the bike final drivve and all
then pull it apart and work on wjatever needs it i put it back the same way caliper stay and all
I have a CB900F front end available to me that I plan to put on this bike. Am I correct in assuming that the spoked GL1000 front wheel would be a bolt on swap or am I wrong?
NobNoc said:
Sorry to jump in late but I have a ton of CX500 parts, hit me up if you need anything.
Will do.
I'm still somewhat in the planning stage. I think my plan is firming up though.
Hoping to post a progress update soon.
jwdmotorsports said:
Will do.
Ignore the seat/tail!! This is a mid build picture, haha.
We did this one awhile ago and I still have a mostly complete parts bike. We were able to hide the electricals and battery (save the regulator) all inside a little leather bag with partitions inside to keep anything from jostling around. It was pretty easy to do! It ran pretty well with pod filters, too, but it took a bit of work to keep it from idling at 2k with the pods.
Yeah. I'll have to hunt it up again but I found somewhere online that listed the jets and everything you need to run with pods.
