1978 CX500 Build
Yep, if not I have some tricks up my sleeve for procuring cheap ones. You'll need 32-34mm. My guess is 32.
BTW, from talking the other day, I think you have several tricks up you sleeve that I intend to take full advantage of.
So, one of the things I want to do is level out the tank and cafe style seat. I've read that you may lose some fuel capacity by doing so. Any negative effects I should be aware of before I level out the tank? Any idea if and how much fuel capacity you lose?
you dont lose much maybe a few ounces
here are a few of my bikes with the tanks leveled the first bike its a little higher than the second
Picked up a CB900F front end courtesy of Kiley's Garage. Bumps me up to 39mm forks instead of the stock 33mm and dual disc brakes.
Glad you can use them. Those forks are feisty...they once fell out of the rafters in the loft onto my head. That was painful. No more.
I'll bolt them down and keep them under control.
So, I had a hair brained idea today for frame modification to flatten out the frame. Feel free to tell me I'm completely crazy and it won't work.
Would still have to add metal to it. When I go to cut the frame, I will probably cut it in such a way as to find out if this will work or not.
fresh_c said:
That seems a bit tall to me, but then again I'm short so ymmv.
Did some more measuring and you would be correct.
Didn't have the front gas tank rubber bumpers when I got the bike. Ordered a set. Just showed up this evening. Now I can mount the tank were it belongs on the frame to dial in frame modifications.
Things to do:
Get the 650 engine onto the frame to determine what needs to be done for the front motor mount. Previous owner decided to hack up the 500 mount. Have the 650 mounts.
Get the CB900F front end together and test fitted to the bike.
Dial in the bike stance and frame modifications.
Hoping to get some shop time this Friday to start making some actual progress on this project.
that is a cx 650 motor you will need to change the out put shaft in the motor or it will not couple
to the cx500 drive shaft
and the 650 mounts wont do you any good on the 500 frame
650 drive shaft wont work on the 500 final drive
and its would be to long even if it did plug in the 650 swing arm is longer
