1979 GS750 build
NBraun
Hey there. A little backround on it, i had wanted a bike for a while to learn on, and learn to work on but my mother wasn't going to let me have a bike. My dad bought his bike and then she found how much fun they are and let me go ahead and get one! This was also perfect timing because i found out my coworker was selling his bike! Ended up buying it for $500 bucks, not to terrible considering the condition of the bike.
Here it is the day we brought it home. 1979 GS750 with 34k on her. Rode her around the block, but it had a vacuum leak and i didn't want to burn up the cylinders.
Got it in the shed and checked the compression, 100,120,120,120, not bad, but something was leaking on the first exhaust pipe.
Since then not much has happened. I dipped the carbs and rebuilt with new o-rings, new gaskets, and they were running great. I had pulled them to upjet and move the needle clips and then for some reason the slides got sticky.
After that i got the valves back into the correct clearance and then kind of forgot about it.
Where im at now. I tried dipping my carbs in pine-sol, that didn't work and made them worse, so now im bead blasting them.
I also have my new tires in (shinko 712's) so i have to get the front rim off and mount them.
As of now im just trying to figure out what i want to with the bike. I need it to be done by riding season here in South Dakota, so that gives me about 3 or 4 months. Im not sure if i want to keep the fender and just make the seat with it. Which by the way the seat has to be a two seater. Being 16 im not going to give up all those chances! Or if i should do a rear hoop. Im just not sure.
Heres a pic that my coworker was given by the PO.
Im also not sure if i want clip-ons or dirty bars. If i get clip-ons i have to go through and shorten all my cables back up.
I also need to figure out what im going to do with the wiring. Im thinking to make sure i can get it on the road to just clean up the wiring and get some side covers on, but ive thought about making a harness and cleaning up the current one. I also need to figure out what im going to do with my speedo. Id like to run only a speedo and make some dummy lights, but well see how that goes.
I also really like the way the bike looks in this picture.
Any ideas or suggestions are appreciated as this is my first time doing anything like this!
Re: 1979 GS750 slow teen build
Great bike to start with....If all goes well i'll be getting a GS750 on tuesday.... Looks as if yours has been well kept PO had a helicopter....I don't think i'll be as lucky, But from my experiences with GS's so far they seem to be built well ....Do you plan on a Cafe or different style? You can really do it up anyway u like. Tons of inspiration on this site and everyone is more than happy to answer questions and help out any way they can.
ENJOY
Compared to some of the bikes on the site, this bike is starting out very clean! Im not sure what style I want to go with. I really like everything, but i switch my mind about every paycheck! ;D Im probably going to go with clip-ons or clubmans but i've read that they can get uncomfortable. Considering this is mostly a town runner it probably doesn't matter but its in the back of my mind.
it looks as if someone has already put the gs1000 carbs on there with Pods so you should be all set in that department....As for bars Get the clip ons they are a bit more adjustable than clubmans....As for a seat you could make it so you can change it out....Tracker style one day Cafe the next....Only thing is most trackers have "superbike" style bars basically similar to dirt bike bars....But make it your own comfortable for you so you'll ride it more often and farther without compromise
Yup, before it got cold i got the bike to be able to pull smooth all throughout with 110 mains and the needle clip moved down one, although it needed the carbs synced. Do you have any recommendations for clip ons? I know some people have had some luck with ebay ones, but im not sure what those ones are. My forks are 35mm and im really thinking like 70 bucks for the clip ons. As for the seat, i have the fiberglass bought to make it, just needs to warm up before i can do it. Probably just do a flat seat with that goes over the fender, but well see.
http://www.ebay.com/itm/35mm-CNC-BLACK-GOLD-Universal-Adjustable-Fork-Tube-Clip-Ons-Handle-Bar-Handlebar-/271002263219?_trksid=p2047675.m1850&_trkparms=aid%3D222001%26algo%3DSIC.CURRENT%26ao%3D1%26asc%3D11%26meid%3D5044381112401366142%26pid%3D100011%26prg%3D1005%26rk%3D1%26sd%3D321057015475%26
these ones are cheapest i could find....Dime city has chrome ones for $70 depends on the look your going for I suppose
Ill look for something similar with those bars. The gold really just doesn't look good to me. But thanks for looking.
mattfeet said:
Curious what process you used for the Pine-Sol dip that didn't work? Care to elaborate?
-Matt
The pine sol is reactive to the metal the carbs are made out of. I left them in there for WAY too long and they had time for it to soak in and really react.
You can always paint them to match ....But Dime city does have some nice ones check out there site you'll probably end up ordering more than just bars
Yeah, im looking at some other stuff at DCC, like the speedo/tach.
What are your opinions on clipons with stock pegs? Some say that clip ons+stock pegs=bad handling bike. In the case that i need rear-sets, does anyone have any ideas on where to put them or mount them? I need to keep passenger pegs but i have no idea where to put the rear sets. Any help is appreciated!
I'm running stock foot pegs with clip ons and it's quite a good fit for me....However I plan on raising the frame rails a few inches/inch and half in the future so I plan on getting my rear sets mounted then when i have a better idea of where they should go....I already bought some Ducati 1098 rear sets for $50 off craigslist...Tons of Ducati owners upgrade to Rizoma rear sets or even better ones so the stock ones are "junk" to them ....as for me i'd never spend $500+ on rear sets adjustable or not
OK thanks! I just hopped onto ebay and now im watching some gixxer 1000 rear-sets. If they go for cheap enough i figure i can get them and see if they work. If not i can just resell em.
Did you shorten your cables on your own, or go with motion pro?
Haha I literally snaked them around and made them work....My "fish" build is nowhere near done since I got the bike and it didn't run so as soon as I got it running I made it my daily driver...it looks like crap to me and I could care less it does 80 in second gear and my last daily driver was a vespa
But you can see in the picture if I raise up the frame rails to be level with the tank it will be a much cleaner cafe look
Oh, your right about the frame rails. That KZ doesn't look too bad. Im hoping mine is pretty quick/torquey. Havn't really had the chance to ride it that far.
Your bike is sweet (especially with the carb upgrade) be careful when you open it up these 750's know how to go
OK.... Now I can concentrate and read your thread. Yours is a looker already, nice score!
appears to me the bikes bars are already superbars, or something close. You're young, clip-ons would be fine, especially the adjustable type. I think the seat looks to have been cut down already as well, maybe just camera angle.
Now the statement on wanting to run speedo only, having a '80 GS750 I can tell you the damn thing goes like stink! My tach was sluggish at first so I never really knew how many RPM's I waswinding it up to. Kinda scary once it freed up, from the sound of it, I musta been shifting about 10 grand.
If I had my rathers, I'd run a Tach only and note at what engine speed 30 then 55-60 mph is and be able to maintain legal speeds that way.
Here is a pic of mine... oppertunity to do a little shameless showing-off
800x600
Ok, you guys got me convinced on clip-ons! ;D
As for the my speedo/tach problem ill probably just do what you want to do and just use a tach. If all else i could use an app on my phone and mount it to the bike to get the general speed.
I also went out and tried sitting on it with my feet on the rear pegs, or where i would want them to be, and i feel that the stock pegs are more comfortable than rear-sets. Guess well just see when i ride it.
Does anyone know of an aftermarket tank cap that just looks pretty cool or different? The one the tank has is all messed up and you can't really use the key to open it up.
Hoosier, you have a pretty good looking bike!
sooo did I tell you I joined the GS750 club today??? traded a moped for it Ha ha....Unfortunately for the bike it's going to the back of the line until at least the DT is buttoned up
