1979 GS750 build
If it has the [] rectangle style fuels filler cap I have one in decent shape that can be opened with a key I'll sell cheap. if your interested let me know.
GK
Way to go desmo! Looking forward to what you end up doing with it!
Thanks for the offer gk, but it has an ovalish/circle cap so it won't work >:(
if you really wanted to go crazy with it you could buy a damaged sport bike tank like a modern GSXR and take the filler out of it and weld it into your tank a couple people on here have done it Looks mint when it's done but it's a bit of work
Ill look into that, but well see. Takin it one step at a time.
Not really an update, as more of just a question. I was planning on replacing the fork oil in my forks when i get the front wheel off, but then i saw that people recommend putting progressive springs and cartridge emulators in. I got looking into this and it can be about a $300 job. Why when you can usually find a modern front end for around that, would you just upgrade your old ones? Right now my suspension is a little soft, but i figured that you can stiffen it up by getting some new fluid in there.
Oh and im ordering my clip-ons tomorrow! ;D
I was so stoked when my clip ons came in....then they sat on the shelf for a month or 2 ....Once I realized how badass they looked on the bike I wished I put em on sooner
and to answer your question about the forks
Modern forks are cool and all but then if you want to run a spoked wheel you need to have spacers machined and it can end up being a bit of work....and in the end you don't have the "classic Cafe" look you have a more resto modded look which is cool but it's never just the forks for $300 there's the steering bearings and what if the stem is too short or too long it can end up being an ordeal if you don't do some research before hand
Ok, i see! Id really love to do an overhaul on em, but i just don't have 300 bucks in the budget for them >:(
On the old zuks you can swap out the front end but as Desmo said it can be a bit of work. Worthwhile if you have the time and cash. If you just want to stiffen up the front end throw in some progressive springs which will run about $80 or less on eBay and new fork oil. I have the same forks on my 750, will change the way the bike feels for ya and is much more comfortable while riding.
Braun, unless you have arms like King Kong, setting your feet on the passenger pegs to emulate rear sets isn't gonna work. The correct position is gonna be somewhere between the original driver pegs and the passenger pegs, ideally directly underneath your butt. It could take a little bit to get the right spot, but it pays off once you fond it. You can research by going online and checkong out the mointing plates for the Tarozzi set for the GS750s. That's what I did. In fact, I think Fast From The Past sell the Tarozzi mounts separately, so you COULD just buy them and mount your sets to them.
Dane, i might just do that. Did you have to put in any new length spacers, or something in the process other than just putting in new springs. Im not sure the length of our forks, but do you thing the springs from mikesxs would work?
RoadRash, your probably right, i need to go get a better feel, or go look at the Tarozzi mounts. I am 6'2 but it did feel stretched! ;D
I am not really sure if the ones off mikesxs would work or not, don't remember the lengths off the top of my head and when it comes to springs I would probably get the ones designed for my bike rather than an xs. Reason being is that the bikes more than likely have different length forks and will have different sprung and unsprung rates which will have different effects on handling.
I don't remember having to add in any other spacers they were pretty much drop in and run, I did mine a few years back. When/if you do it you will probably want to change out the fork seals and dust boots as well, cheap parts and worth the few extra bucks if you are going to be in there.
Here is the set I think I got for my L series:
http://www.ebay.com/itm/Progressive-Suspension-Fork-Spring-Kit-Suzuki-GS750L-1979-1981-/390520173084?pt=Motorcycles_Parts_Accessories&hash=item5aecd0f21c&vxp=mtr
Which series is your bike L or E?
Ok you have a good point about the mikesxs springs. I happen to have an L model. Thanks for the link!
A small update guys!
Today i went out to try and figure where im going to put my clip-ons and realized that the stock headlight ears weren't going to be able to be used so i went ahead and took the top tiple off. Im working on getting the dash off, but one of the screws holding the headlight together is stripped, so ill have to figure that out. There is this rust that was underneath the ears, whats the best way to get this off? Simple green and steel wool?
Theres a pic.
Im probably going to put an order into DCC for headlight ears and if nothing else a new mini tach. Im trying to decide, what to do with the electrical. Id like to at least keep the idiot lights, but not sure if i want to do it with LED's and i really don't want to be rewiring anything, and theres quite a few plugs that have to do with the dash of the bike. Any thoughts?
One more thing. I see people get newer MC's off of sportbikes, whats the point of this? Being able to run the aftermarket levers?
Thats all as of now, hopefully my clip-ons come in tomorrow! Thanks!
That will clean up with some never dull unless it has really deep pitting that i can't see...If you end up ordering the gauges you may want to cut a flat piece of aluminum or steel and make a dash with idiot lights...Lots on here have done it and it looks really clean once all zipped up. wiring will be that hardest part but just do you homework before hand and go one at a time
Sorry about the blurryness of the pic. Easier to just use my phone haha. It looks to just be on the surface.
Will i have to solder in resistors for them? Not totally sure on this, but thought i might have read that somewhere when switching to LED turn signals.
yea LED's do require a resistor since they require less amps but they are easy to find and wire in from what i've heard
Ok, might just be easier to but the speedo from DCC with the lights. That way i can have a speedo too!
Well i went out again to try to find something to do. Took the exhaust off and now figured out why theres oil all over the front of the engine. There's no way that those bolts were torqued to the right spec, or were even close. He didn't have any gaskets either! ANYWAYS...
Now i have to decide whether to pull the engine or not. If i did, i wouldn't tear it apart, just clean it. But it would seem much easier to clean outside the bike. Opinions?
Pics of said oil. What would be the best way of going about cleaning it? Cleaning inside the spark plug valleys?
To clean the engine and plug galleys make sure your plugs are tight, snug them up with a plug socket and use some simple green and degreaser to clean the engine. It would probably be easier to clean with the engine out of the frame but not necessary. All depends on the amount of work you want to give yourself ;)
The oil is more than likely coming from two places on your engine. The valve cover gasket is fairly notorious for leaking on the 750s and also where the cable goes into valve cover for your tach. If you can find some NOS gaskets for the valve cover and should just need a new o-ring for the tach gear that would get it squared up pretty cheap, also would suggest checking the valve clearance if you have not done it yet.
Im being completely serious. There was no gasket on the pipes.
As for the oil. Ill pick up some simple green tonight and get to work on it. I changed the valve cover gasket to an OEM one when i checked the valves. The PO had just used gasket maker, Ill also look into the tach O-ring. Thanks!
Well i bought 35mm clip ons because that's what i found on the internet. Turns out i have 37mm forks...sooo ill have to figure something out. Either send them back and trade them for some 37mm ones or get a refund or sell these ones and buy different ones. I don't think ill be able to get them to work, but does anybody have any thoughts on gettin these to work with my forks?
