1993 CB250 Build
CALfeRacer
Fat man on a little bike
Here we go, its a day of firsts! I bought a new bike yesterday, and I'm proud of this one ;D. It's a '93 Nighthawk 250, and as I said, its a bit of new territory for me. First bike I've bought that isn't from the 70's, has more than one cylinder, runs, rides, has a title, has electric start, and first that isn't intended to go full project/ cafe. I want this bike to be something to ride around, get loads of experience on, and just thrash.
So, I come to you seeking advice on general running for now, and it might get some MILD cafe mods along the way.
The bike is having electrical issues. Starter doesn't work, nor do any of the lights (I have to push start it). Once it is started, it idles great, and runs strong. I charged the battery today, and still nothing. Connections all look good, fuses are fine, and the battery terminals look good. Any thoughts? I'd like to get the electrical bits working, so I can legally ride around.
Speedometer doesn't work either, is there any way I can test to see if its the cable before I go and buy a new one?
Thanks all, and here is the picture of it on the way home.
It looks like this bike might have been dropped, which could have loosened a ground somewhere. Could be the cause of your troubles.
Oh, it has. You should see the other side of the tank!!! :o
I'll check the grounds tomorrow
I got excited and ended up checking the ground tonight. I cleaned it off with a wire brush, and the spot it contacts. Still nothing happening with the electrical or lights.
I ended up shorting the solenoid, and the starter went good and strong. I will be buying a new solenoid and will hopefully be riding around as soon as possible! Also, I got some studs to replace the broken off exhaust stud, so it should be running right by tomorrow (I have to go to the shop to use an Easy-Out to get the end of the stud out).
From what I understand, if you short the starter solenoid and the starter turns, the solenoid is good someone correct me if im wrong. The culprit might be the engine start switch/button.
Yeah, I think you may be right about shorting the solenoid, which brings me back to a bad ground somewhere.
Well, I'm a f***ing idiot and managed to punch a hole in my head trying to remove a broken exhaust stud. That puts a big dent in the whole idea of cheap daily rider... Ha. Anyways, debating parting it out or spending the $$ on a new head. If anyone has a head for a nighthawk or rebel that you're willing to let go of, I would be forever in your debt. Thanks, and hope everyone else is having a better day than I am!
japsche said:
Ouch.
Shortest build ever?
Hahahaha hopefully not. I'm searching for a reasonably priced head now, and trying to figure out if the rebel head will fit on a nighthawk. Everything I've seen says the engines are the same, but I can't seem to get a definitive answer on whether the heads will swap. I really want this bike to scoot around on and maybe make some simple mods on, but who knows. If I'm gonna be better off parting it and using the $ to but something better, then so be it. And I can enter for the "Shortest Build" award. Do I get a trophy or anything? ;)
how bad is the damage?
Basically, the hole where the exhaust stud would go is now punched through to the inside of the head. Some oil leaked out when it happened. Can that be repaired?? Or am I just better off going for a new head?
my first guess would be yes, just by blocking the hole, and/or replace thread(unless you drilled something to bits in the head) But its 2 am so im not quite sure lol.
Nothing in the head got touched, as soon as it went through (I thought it was the bottom of the stud) I pulled it out. The threads are still being taken up by the remains of the old stud, so I would have to get those out. What could I block the hole with?? Also, where are you that its 2AM??? haha
well ok it doesnt sound like a new head to me. I would take off the valve cover and make sure no metal shards got in the head, then i would drill a hole for a m8 thread, put some liquid gasket on a stud bolt and mount it.
Then you would have blocked the hole and gotten a new stud all in one go:) its worth a shot imo. Im in Denmark, my best friend was operated earlier so im watching over him as he sleeps, but im often up at this hour, looking at bikes here hehe
Alright, I think that doesn't sound too bad. Worst case is I end up with a slightly larger hole in a head I was planning on junking anyways... I'll head up to the shop tomorrow and do that. Thanks for the advice!
Also, I hope your friend has a good recovery, and you find a good bike as well :D
yea that was my thoughts on it as well, just seems a little rash to change the head for a broken bolt:) Hope it works out for you but i advise you to get a second opinion anyway. And thanks, he will be wrenching again in no time im sure:)
I'll get a second opinion from the local shop, but I don't see the harm in just going for it haha
Exhaust Stud Options
So, after a long week, I will be able to work on the bike once again, chief issue being the hole punched in the head through the exhaust stud hole. I have come up with three options (short of buying a new head) and was interested in getting some opinions. Picture should be self-explanatory, however feel free to ask questions or tell me I'm an idiot. Thanks!
Option 1 imo :D
That way you dont have to worry about the nut coming off the stud and flail around in there.
And just use a locking disc on the bolt if youre worried about it coming off. If youre worried about leakage, dont be lol. The liquid gasket seal on the thread will hold on its own without the need for a gasket and nut
Reason for using m8: if you drill the hole for m7, you might still see the old thread, afaik you only need 1mm for the thread in that size. 6,8mm drill for m8 for a strong thread. But ive used 7mm drill with no problems in the past.(for m8 thread) and 6mm drill for m7.
Edit: here is a chart for hole sizes when doing threads.
Edit2: ok maybe that pic doesnt show but as a rule of thumb you take the size of the bolt you want to use, then subtract the amount of pitch in mms for the predrill size before threading
Ok totally misunderstood option 2, seems like that would work as well, but then you might need to pull your valve covers just to tighten the stud bolt?
