1993 CB250 Build
Well, I can just make it more simple based on what I did today!! haha
I decided to put in a helicoil for a M8 bolt, since I got the handy flashlight and peered in to the hole, and noticed there was a back to the hole. I must have nicked an oil passage or something, because it most definitely had a back and did not go in to the valve area (I pulled the cover to check). So, its just being held on by the M8 bolt in to the freshly threaded and helicoil-ed hole.
Sounds good as long as no oil passages are blocked by the bolt :o
Got the new exhaust gasket and collars on today, and she is alot quieter... kind of sad! I now really want to do the 2-1 exhaust and maybe some work on the intake side to help her breathe a little better. I've been reading the huge thread about everything engine on here, and it is really inspiring me to make the most out of this bike as I can, while still retaining some resale value (I'll probably be selling this by the end of spring quarter and moving up).
Ran it for a few minutes with the exhaust all tidied up, and she isn't running right. Low end she sputters and stalls, no throttle response whatsoever. I figure the PO either tuned it to be running lean (due to the exhaust leak) or something is stuck in the pilot jet. Once the throttle hits mid range, everything is fine and revs up very well. I'd rather just run some seafoam or something through the gas, but if that doesn't work, I'll tear the carb apart and clean the jets.
Electrics still don't work. I think it might be due to the old, worn out battery. New solenoid is in the bike, but still no starter action, or any lights at all when running. This confuses me. I checked the grounds, and they are all good. I know the starter cranks, I got it do do so by shorting the terminals on the old solenoid. Any ideas?? I'm gonna go down to autozone tomorrow to get the battery load tested and go from there.
Sorry for the dense post, but alot of things are going on right now! Figure I'd shift away from bitching about the exhaust stud to some new stuff.
Anyways, thanks everyone and have a good night!
Couple squirts of carb cleaner and she's running like a top.
I'll be changing out the brake shoes tomorrow hopefully, and my speedo cable/turn signals should be here by the end of the week. Yay progress!
Well, I've put about 80 miles on this weekend. After an interesting first ride, consisting of trying to do highway speeds, running out of gas, and losing air-holding ability in my front tube, I've had a good time. Also, figured out a clue in the wiring mystery. I've been riding around without lights, and I think I found a culprit. Today on the way back from the carwash, I managed to forget to turn the key to "ON" but still was able to ride home. Something ain't right here. Took the switch out and one of the wires was missing some insulation and the insides a bit frayed. I figure this could explain why nothing happens when the switch is turned to on, and explains the total lack of lights or starter. I'm looking in to getting a new switch now, after testing it with a multi-meter tomorrow. I figure the bad black wire (which is part of the circuit that is closed when the key is "ON") could be the source of my troubles. We shall see!
Yay for forgetting to post updates...
I finally figured out the electrical issues. Yay!
Now I'm looking in to making it a bit more custom. Namely, a solo seat and cowl. I have no desire to carry someone around on this thing, the bodywork is s**t, and I want to make it a little more custom ;). I have a CM250C seat that I'm going to cut up, maybe use the cowl from the stock bike to make something snazzy, and cut the back end of the frame. Also on the look out for a new tank. As far as the stud replacement, I'm on to a new solution. I'm leaking oil from the stud despite some liberal use of loctite, so I am going to place an M8 stud which I made from a bolt that was about 10m longer than what was necessary and JB weld the bugger in place after threading it in to the helicoil. Then use a M8 nut to hold the flange on. This way there isn't a hole for oil to squirt out of. I'll post pictures when (if) I cut the frame and make the custom seat. Also have a rebel 250 front end tracked down that I'm considering buying to get beefier forks and a front disc. This weekend I'll be attempting a ride along the PCH up to Santa Cruz, so that should be interesting... I did 2 hours of riding on easter so I think it should be fine. I'll take a break halfway. ;)
