6v Coil/Condenser setup
adventurco said:
So, you can just slap a 12v R/R in these and it's a 12v system?
More or less, yup.
The headlight circuit is AC, though. So you run a 12V AC inline regulator on that portion and you can use a 12V R/R setup for the rest. Ignition system is also it's own circuit, so you usually leave that alone.
Sonreir said:
More or less, yup.
Looking at the coils, one is wrapped with a larger gauge wire/less turns one smaller/more turns lighting and one ignition. when i need to data log a single 20 amp circuit I wrap the CT with 14ga wire exactly 10 times to get better data then / by 10 for actual consumption. I bet somewhere someone has 12V windings for these XL's
