Thank you for the kind words MBS! I hope to work on getting the cam installed this weekend. At that point, should be getting close to putting the engine back in the frame.
Kev
A good weekend. This morning, i got the head torqued, valves set and points gap set. This afternoon I covered the frame rails up and hung the engine. I may get this thing done someday!
Kev
Tonight I fiddled around with making a set of plug wires. 7mm solid core with NGK caps. I made a rubber liner for inside the battery tray and made a ground cable. I'm working on the shift linkage now. Next step is to weld two little stops on the header pipes and I'll be able to install the exhaust.
Its nice putting parts on that don't have to be taken off again! Looks like I'm actaully doing something, hahaha
Kev
