These are all questions that have been posed here several times. (I dont say that to be rude, just to let you know that there is a basis for my answer...)
"Upgrading" to usd forks is (in my opinion) for show only. They arent designed to be used on your bike. Actually upgrading the stock units with high end parts is the way to go.
The stock rear shocks on any old bike leave room for improvement. On the 500/550s this especially rings true. Upgrade those right away and you'll notice a HUGE improvement in ride and handling.
As far as a wider rear tire/wheel, why? Its another show only "upgrade". The bike doesnt produce enough power to facilitate a wider rear tire. Also, adding width to the rear will effect handling. Likely for the worse.
You can do some really great stuff with these bikes by rebuilding and updating the stock components.
That said, if your end goal, is a show piece (which is all good, not giving you a hard time honestly) than go for it. But, if you want a real rider, its all unnecesary (minus the rear shock replacement).
