77 CB550 questions!
Sophia550
do a lot, say a little
I have seen bikes with a gsxr 750 front end on the cb550's, wondering if anyone has any experience on doing this, and if it make a difference. thinking if i were to do that i would change the rear shocks for the race tech ones that i have seen in the cafe racer mag. im also interested in have a wider rear tire but am unsure on what swing arm would be good for that.
Thanks! ;D
Sofi
These are all questions that have been posed here several times. (I dont say that to be rude, just to let you know that there is a basis for my answer...)
"Upgrading" to usd forks is (in my opinion) for show only. They arent designed to be used on your bike. Actually upgrading the stock units with high end parts is the way to go.
The stock rear shocks on any old bike leave room for improvement. On the 500/550s this especially rings true. Upgrade those right away and you'll notice a HUGE improvement in ride and handling.
As far as a wider rear tire/wheel, why? Its another show only "upgrade". The bike doesnt produce enough power to facilitate a wider rear tire. Also, adding width to the rear will effect handling. Likely for the worse.
You can do some really great stuff with these bikes by rebuilding and updating the stock components.
That said, if your end goal, is a show piece (which is all good, not giving you a hard time honestly) than go for it. But, if you want a real rider, its all unnecesary (minus the rear shock replacement).
I can agree with Von on that. Especially the rear tire aspect. These small engines dont have the ouput to warrent the use of a wider tire and it will throw handling off. And just IMHO these lil bikes dont look right with wider tires in the back.
I have a CB550 that I wanted to do a dual disk conversion on. If you are not set on the GSXR you might want to consider 75-77 GL1000 front ends. Its a pretty easy swap and you are staying within the same family so to speak.
