Thanks alot guys! Well there was a huge delay with the machining for the rear end but it is standing on its own two feet for the time being. The rear end swap was a BITCH!!!!!! Now I am going to fit all the electrical and have the front wheel machined down, so I can loose the interceptor front.
Not a whole lot going on, waiting for the front wheel to be machined. Finished all the wiring I could, moded some aftermarket hurricane pegs to fit the interector mounts, fitted the new exhaust and the hurricane forks and calipers in the interceptors triples.
Ok, got the front wheel back, had the tire mounted installed 600 f1 bearings, waiting on f1 front axle. Mock up of as it sits now. hopefully be starting tank soon.
nothing to exciting, front wheel machined down everything bolts up! Cut down the 600 front fender, and mounted entire exhaust. Will be starting the tank in the next couple of day.
Thanks guys! The exhaust colector is straight up vf500. The tips are suppertrapp external discs from summit racing, they are like $50 each. Like all super traps they adjustable for noise and flow.
Thanks again
No real updates! Started modifing the tail so it sits on the rear subframe correctly, also started the tank. I have been doing alot of parts ordering, and picked the paint colors now I have to decide on the scheme. Here are the options on the table
something like this http://www.flickr.com/photos/teamheronsuzuki/3649828569/#
Hey thanks rattlecan! Xmas in May!!!!! Its going to take a little work but it will work!!!! ANd I think is going to look cool! Started the tank as well.
Thanks guys! It all is hanging under it own power now! All that was needed was to add about 2 inches to the bottom of the lower to widen it, and some trimming here and there. windscreen came in here it is all mounted, this may be the last post till its done, hopefuly that will be soon.
