Another cb 360t, but with a sexy twist.
Doesn't look too bad position
The new welding makes the original Honda stuff look even worse ;D
I should have remembered from cycling, women tend to have longer legs in relation to total height so you probably need to sit closer to tank to reach bars?
Personally I prefer the set to cover the frame tubes
It makes it wider and more 'comfy'
I like what you did with the rearset bracket, but I still can't figure out how I'd be comfortable on my 360 with rearsets that are even higher than my stock pegs (albeit further back). I'm not the tallest person either, but I'm still drawing a blank when I'm experimenting with foot positions
Even with padding on the seat, your legs will be bent more than you really want them to be. I would move them down an inch or two to give you a little more room . Looking from the side, they will probably end up in line with the swingarm or maybe slightly lower
Alright.... I am back :P
A lot has happened in these last months so I'll post all my achievements :)
I decided to hack the end off... since I needed clearance...
I modified the end to a point so I would have maximum clearance with the battery tray...
Ok I also solved the issue with my tank and petcock by cutting off the tank brackets and moving them back... Replacing the big gaping hole with some steel pipe... After all the miscellaneous fabrication that I had done. I decided I was ready to paint. So here are some pictures of the cleaning process:
Here are some pictures of the tank... sooo shiny
Thus began the era of bondo... I thought my garage looked like something out of Scarface after I was done...
After that I sprayed the primer... making sure everything was still smooth
Now the paint... Both were DuPont professional paints... The body was a flat sage green and the tank is a glossy off white... First time painting with spray-guns and respirators... Came out great for a rookie :P
PS. Pictures keep flipping upside down... but you get the picture (no pun intended:P)
After curing for quite a while I was able to see how they turned out
So I spent some time today an yesterday and put this thing together... she is gorgeous... A lot of work still to do, but it is well worth it...
Hell yea...For a year there I was thinking you dropped off the planet.
Its great to have you back and she is looking awesome!!!
You've really been putting in the hours.
Looks great! I dig it. A little wiring and taking that first ride. KEEP IT UP! That seat and tank looked very cool bare metal, and would be cool cleared for a steam punk look.
Thanks guys! a year... wow... when did life decide to take control? Wiring and the cables for the throttle and clutch are my next endeavors...
CB200 tank looks better in white than it ever did in green 8)
Year here, year there, whatever ;D
Since I have now finally caught up my blog with my build...
I am currently working on the seat upholstery. Using the same leather you can see on the tank. I plan to hand stitch the whole shebang with a sewing awl. (since this leather is fairly thick and I don't have a nice industrial sewing machine) Right now I am working on where my buttocks would go. I decided a plain seat is nice, but not fitting for the bike (looking for a little flair). I decided to find a geometric shape from the internet and use it as a embroidery on the seat cushion. Fairly simple and abstract. The thread is a nylon wax and fairly heavy duty. Here is some of the pictures of where I am going with this...
