Are you going to be leaving the hexagonal shape of the cowl or going to be making it spherical? If you are just cleaning it up and keeping the edges and lines, bondo will be fine. But if you are going to make it round you might want to invest in dynaglass before you use bondo. Bondo isn't really made to cover thick areas..
I Agree with Ronnie.
However, I think it looks really cool with the panelled shape you have from framing it in wire first. Looks really cool against the lines of the tank!
Think its pretty clear that shes going for that shape to flow with the tank, then bondo'in the imperfections and rough spots smooth not to alter the shape at all.
So I have some finishing touches on the seat and tank, the seat I added some bolts to have a secure mounting system which go through the tabs on the frame
I also ground the seat with a finer grit... so the glare from the seat makes it hard to see the details...
